Stop doubling tabs in the same window
Posted: 26.10.2016, 14:24
Right now if you click an icon from a Favorite Toolbar that is a proper / working shortuct to a folder, the folder is opened. And that is how it is supposed to work
But why does clicking it the second or third time, either accidentally or because failing to see where a tab with that already opened folder is, results in creating a new tab with the same content; and not just making active [switching to] the already existing tab?
Yes, I have specifically put a Parameter for a new tab in all of my shortcuts. But that was to prevent the lost of other tabs in my workflow- but dealing with that problem created a new one, of repeating tabs with the exact same content. FreeCommander should check first if a desired location is not already opened and not created a second or third tab with it
