R333: Enter folder issue
Posted: 20.04.2008, 21:23
- create 3 folders, A, B, C
- select A and B folders (with Space or Insert key)
- press ctrl+x to cut the folders
- go to folder C
- press Enter to enter the folder C
= folder C is not opened, folders A and B are opened as the new explorer windows instead
Explorer has crashed when I tried this with many folders with video files inside.
Probably it's a new feature, useful for files, but not for the folders.
...So even if two or more FILES are selected, I can't copy/move those files to any subfolder, when I try to enter the subfolder, the files are opened instead. It should be always possible to enter the folder with Enter, even if any files/folders are selected.
FC R333, Window XP SP2.
- go to folder C
