History of changes
Locked
Preview of the future Version
#1 Post by Marek » 22.12.2009, 20:23
The first preview of the future version of FreeCommander is now available for the donors.
Preview version - release 505
#2 Post by Marek » 27.02.2010, 23:10
The next preview relase for the donors is available.
Important news:
- FC delete operation in background
- Set Attribute/Timestamp operation in background
- WCX plugins (now only browsing; operations are not implemented yet)
Preview version - release 507
#3 Post by Marek » 14.04.2010, 21:41
Important news:
- many bugs fixed
- some new settings
- file operations continued
Please test the file operations.
FreeCommander 2009.02a donor Build 412
#4 Post by Marek » 02.05.2010, 18:29
You can now control auto complete with the following line in the freecommander.ini:
[Form]
PathEditAutoCompleteSource=x
where
x=0 - auto complete off
x=1 - auto complete list from FC
x=2 - auto complete list from Shell
Preview version - release 508
#5 Post by Marek » 06.05.2010, 22:33
Important news:
- with Ctrl+Shift+F10 you can call/test the context menu with items from the 64 bit programs
- many of your suggestionsto the last build are implemented now
If context menu 64 properly functions, I will also use it for the version 2009.02a.
Preview version - release 510
#6 Post by Marek » 20.06.2010, 21:11
Important news:
- you can call 64 bit context menu with right click
- for calling 32 bit context menu use LeftWin+RightClick
- if you prefer to see for right click always 32 bit context menu: define ShowContextMenu64Bit=0 in the [Form] section
- delete and unpack operation for WCX plugins are ready for testing
- many small bugs fixed
Preview version - release 511
#7 Post by Marek » 26.06.2010, 09:38
Important news:
- AutoClose for 64 bit context menu (ca. 10 sec.)
- some bugs fixed
FreeCommander 2009.02a donor Build 413
#8 Post by Marek » 06.07.2010, 20:35
  • Bug fixed: IP address and computer name doesn't work when entered in address bar
    Bug fixed: multirename replace function doesn't work on folder names if you want replace the dot char
    New: 64 bit context menu will be showed on Windows 64
You can now control 64 bit context menu with the following line in the freecommander.ini:
[Form]
ShowContextMenu64Bit=1
AutoCloseTimeContextMenu64Bit=10
You can call 64 bit context menu with right click
- if you prefer to see for right click always 32 bit context menu: define ShowContextMenu64Bit=0; with LeftWin+RightClick you can call then 64 bit context menu
Preview version - release 513
#9 Post by Marek » 26.08.2010, 21:47
Important news:
- Pack/unpack operation on archive files (define your plugins under Settings->Archiver plugins)
- Internal ZIP plugin with encryption and ZIP64 support
- bugs fixed
FreeCommander 2009.02b Build 418 donor
#10 Post by Marek » 25.09.2010, 15:07
The donor build of the new version is available.
Preview version - release 514
#11 Post by Marek » 28.10.2010, 19:36
Important news:
- Viewer and quick viewer implemented
- bugs fixed
FreeCommander XE preview version - release 515
#12 Post by Marek » 21.11.2010, 10:28
Important news:
- The preview version renamed to "FreeCommander XE"
- File converter (text filter) for viewer - how to use
- Bugs fixed
FreeCommander XE preview version - release 516
#13 Post by Marek » 05.12.2010, 19:40
Important news:
- Basic drag&drop implemented
- Bugs fixed
FreeCommander XE preview version - release 517
#14 Post by Marek » 05.12.2010, 23:15
- Drag&drop worked not as expected.
FreeCommander XE preview version - release 518
#15 Post by Marek » 11.12.2010, 17:09
- Drag&drop problems fixed
- Other bugs fixed
Locked
Users browsing this forum: No registered users and 24 guests
