History of changes
Important changes and bug fixes in the release 917
#361 Post by Marek » 03.11.2024, 19:04
- Bug fix: Exception may occur if "Automatic views" are active and quick filter field is not visible
Important changes and bug fixes in the release 918
#362 Post by Marek » 03.12.2024, 20:00
- Bug fix: Selection in thumbnail view may be lost after refresh
- Bug fix: Context menu item "Share" does not work (Windows 10, 11)
- Bug fix: Drag&Drop from new Outlook app to FreeCommander does not work
- Bug fix: When "One tree per panel" is active and base folder for the tree is "Drive" then copy from/to ftp may cause changing the ftp panel to desktop folder (tree refresh problem).
- Changed: Automatic views - quick filter option "Not used" and "Apply" added
Important changes and bug fixes in the release 919
#363 Post by Marek » 12.12.2024, 19:17
- Bug fix: Dragging from the search dialog or from file container does not work with some programs
- Bug fix: Exception when selecting the favorite folder from the pop-up menu that opens by clicking the button in the address bar
- Bug fix: Exception may occur in the search dialog on disabling Quick Viewer
Important changes and bug fixes in the release 920
#364 Post by Marek » 21.12.2024, 13:05
- Bug fix: Exception is possible if deleting files while quick viewer is open
- Bug fix: Exception is possible if the quick viewer is clicked during in-place editing in the file list
FreeCommander XE 2025 Build 920 32-bit public
#365 Post by Marek » 21.12.2024, 14:23
Important changes and bug fixes in the release 920 compared to 900
- Implemented: Create folder F7 from full path (c:\aa\ab) is possible now
- Implemented: Using of the built-in icons is now possible for action toolbar, favorite toolbar and tabs
- Implemented: Quick operations (quick copy, quick move) are possible; Settings for quick operations: "Tools->Settings->File/folder operations: Quick operations"
- Implemented: Multi rename - option for definig of the timestamp format for exiftool in FreeCommander.mren.ini: ExifToolTimestampFormat
- Implemented: zst archive for Total7Zip (with Modern7z www.tc4shell.com/en/7zip/modern7z/)
- Implemented: New action added - Sort by created date
- Implemented: New actions for quick operations added: "Perform quick copy...", "Perform quick move", "Quick operation - set target path..."
- Implemented: Free area context menu - added items "History back", "History next"
- Implemented: New option for tabs - Show close button on all tabs
- Implemented: The queue dialog size and position is saved now
- Implemented: Copy, move and delete dialogs - size and position are saved now
- Implemented: Search duplicates - new items added for "Duplicates selection": "Mark all with the path pattern...", "Unmark all with the path pattern..."
- Implemented: Search dialog - encoding 'Unicode (UTF-16LE)', 'Unicode (UTF-16BE)' added
- Implemented: Saving and loading tab groups is possible (View->Tab groups)
- Implemented: Search files/folders dialog - "Accessed" column added
- Implemented: New actions added - "Sort tabs in ascending order", "Sort tabs in descending order"
- Implemented: Settings->Folder tabs - "Use for sorting" options added
- Implemented: Multi rename dialog - shortcut Ctrl+E defined for "Rename using text editor..."
- Implemented: Copy speed and time remaining is shown in copy dialog for "Use FreeCommander" method
- Implemented: Settings->File/folder list->Mouse shortcuts - for right mouse button new action is possible "Focus item - thumbnails view"
- Implemented: Compare folders - compare files by content (md5 sum) added
- Implemented: Attribute/Timestamp dialog - setting timestamp from Exiff of the HEIC files is possible now
- Implemented: "Settings->View->Icon sets" new option available "Use dark mode icons for color schemes"
- Implemented: It is possible now to copy to multiple selected folders in File Container
- Implemented: New Exiff columns in detail view are possible now: Latitude, Longitude
- Implemented: New option under Tools->Settings->File/folder list->General: Timeout in milliseconds when accessing network drives
- Implemented: New option under Tools->Settings->File/folder list->General: Shorten long file names with ellipsis in the middle
- Implemented: Column profile is now overridable after auto selected view freecommander.com/forum/viewtopic.php?p=43461#p43461
- Implemented: Multireneame dialog - button in the status bar for filtering changeable or erroneous lines
- Implemented: Setup should works on Windows ARM64
- Implemented: Automatic views - it is possible to define quick filter for each view
- Implemented: Quick filter - switch /+ can toggle the option "Also use for folder names"
- Implemented: FC copy dialog - show hint if available free space on target drive is smaler as total size of files to copy
- Implemented: "Paste" and "Paste link" added to the context menu of the address bar
- Changed: It is possible now to define alternative status text in the FreeCommander.onedrive.ini. Example: 3=Keep on this device|Always available on this device
- Changed: Tab properties - if changing of the locked path in active tab the file list in the tab is reloaded with the new locked path freecommander.com/forum/viewtopic.php?t=13736
- Changed: Toolbar customizer - in the Description column show only description
- Changed: Edit->Save selection to file - file extension changed from *.sel to *.fcsel; Double clicking on *.fcsel will perform the action “Edit->Restore Selection from File”.
- Changed: Compare folders - compare files only by size is now possible
- Changed: "Settings->View->Icon sets" - icon set "Flat" is no more available
- Changed: Settings - changing the start background color now always changes the end color. This is controlled with the freecommander.ini option “AutoSetBackgroundEndColor=1”; default is 1 (true)
- Changed: Viewer is now linked to the panel from which the viewer was opened and not to the active panel
- Changed: Keyboard shortcuts dialog - background color of the active shortcut column is bad for Window high contrast scheme
- Changed: Attributes/Timestamps dialog - the separator in the file with saved timestamps is changed from "=" to "?"
- Bug fix: Click on tab does not activate the site freecommander.com/forum/viewtopic.php?t=13723
- Bug fix: Windows 11, Option "Show popup menu for left button drop" is broken
- Bug fix: "Tools->Toggle font size" raise exception if menu is defined as toolbar
- Bug fix: Multirename with exiftool is broken
- Bug fix: Viewer settings - saving EXIF tags per file extension does not work if tags field is empty
- Bug fix: Favorite folders tree - after adding new item or removing item all tree items disappeared (rarely happens)
- Bug fix: Exception possible on activate or deactivate settings dialog from the taskbar (after opening first the viewer settings in the settings dialog)
- Bug fix: Tree panel position after switching from one to dual panel maybe wrong (if option tree per panel is used)
- Bug fix: Thumbnails - option "Show only files" does not work if switch from non thumbnails view to thumbnails
- Bug fix: Replacing existing files during the synchronization is slow freecommander.com/forum/viewtopic.php?p=42464#p42464
- Bug fix: Compute Checksums "Copy to clipboard" button does not work for lines where the sum is not equal with the pattern sum
- Bug fix: Image viewer - options "Fit to window" and "Original size" does not work properly
- Bug fix: Tree refresh problems freecommander.com/forum/viewtopic.php?p=42563#p42563
- Bug fix: Changing the color of the font in the title bar of the file list is not possible (color is saved in the color scheme .colors file) freecommander.com/forum/viewtopic.php?p=42578#p42578
- Bug fix: Mouse shortcut - rename on ".." item does not open multirename
- Bug fix: Favorite tree - flicker on refresh
- Bug fix: Thumbnails are not displayed when "Plain view - files" and "Show only files (no folders)" are active
- Bug fix: Freecommander.exe may disappear when plugging/unplugging some USB devices
- Bug fix: "Switch locked folder to current" is broken
- Bug fix: Focused item is not always visible if view is changed back to parent folder
- Bug fix: Save selection, Restore selection, Save selection to file, Restore selection from file - does not work properly for plain view
- Bug fix: Focused item is not always visible if go to parent folder is performed
- Bug fix: Auto refresh may not work if copy/move/delete is performed with Android folders
- Bug fix: Create folder with F7 is broken if subfolder is used e.g. "folder1\folder2"
- Bug fix The auto-selectable view may not be found for "This PC".
- Bug fix: It is possible that the program cannot start (due to an exception) after closing if the tree splitter was in a certain position when closing.
- Bug fix: Exception on saving settings for quick filter - if only one panel is visible
- Bug fix: The display of the selected items count in the status bar may be incorrect freecommander.com/forum/viewtopic.php?p=42834#p42834
- Bug fix: Quick filter is activated unnecessarily freecommander.com/forum/viewtopic.php?t=13827
- Bug fix: Lock toolbar does not work if action toolbar and favorite toolbar are locked in one step freecommander.com/forum/viewtopic.php?p=42869#p42869
- Bug fix: After using F10 (Dual/one panel), command "Customize toolbar" from context menu of the address bar does not work
- Bug fix: Wrong overlay symbol in the file list if switched from list/details to thumbnails
- Bug fix: Search duplicates - exception when clicking on selection button if md5 calculation is not yet completed
- Bug fix: Compare folders may not work if plain view is active and the option "Reload both lists before compare" is active too
- Bug fix: Some copy/move actions (buttons) are not showed on splitter toolbar
- Bug fix: Several pages in settings dialogs showing incorrect background color with windows high contrast theme
- Bug fix: Color picker - wrong size for scaling < 150%
- Bug fix: Searching in the root folder (c:\, d:\...) will not return any results if the "Ignore" option is set to a value other than "None".
- Bug fix: Viewer - colors for text font and background are not used although the option "Use scheme colors if active" is not active
- Bug fix: Favorite folder selected in popup menu from the favorite set and category is not opened
FreeCommander XE 2025 Build 921 32-bit public
#366 Post by Marek » 27.12.2024, 19:13
Important changes and bug fixes in the release 921
- Bug fix: Keyboard shortcuts are not displayed in English
Important changes and bug fixes in the release 924
#367 Post by Marek » 28.01.2025, 19:28
- Bug fix: Timestamp format does not work properly if date separator defined in FreeCommander is not the same as in Windows
- Bug fix: Multi rename profile can not be renamed
- Bug fix: Tabs are not visible if "Tab position" is set to Bottom and "Tab style" to Cut Corners
- Bug fix: Focus in the file list is lost if archive file cannot be opened
- Bug fix: The definition in "Exclude the following files:" in "Set filter" dialog does not work if "Regular Expression" option is active
- Changed: Multi rename dialog - option "Exclude extension" is active per default
- Changed: Assign local path (reparse point) as network drive - in address bar the target address of reparse point is displayed and not the drive letter
- Implemented: New option "Show sorted list" added for "Settings->View->Folder Tabs: Tab Management"
- Implemented: New option "Stripe in active panel only" added for "Tools->View->File/folder list->Color/Font"
Important changes and bug fixes in the release 925
#368 Post by Marek » 29.01.2025, 21:04
- Bug fix: File inside archive file can not be opened with F4 (Edit)
Important changes and bug fixes in the release 926
#369 Post by Marek » 20.02.2025, 19:54
- Bug fix: The icons in the Queue Form can be wrong if using dark or light icons
- Bug fix: When the quick view is open and settings for the position of the quick view panel is changed, the old panel will not be closed
- Implemented: New option for copy/delete dialog - "Automatically scroll the file list" (default is no scroll, is faster)
- Implemented: Folder size in archive file (details list) will be showed for the shortcut Space
- Implemented: Tab can be moved per drag&drop to other panel if on drop the Ctrl key is pressed
- Implemented: Column profiles - new property for "OneDrive Status" column: Column for 'Availability Status'
- Implemented: New internal archiver plugin "fc_internal_7z" (64 bit only)
Important changes and bug fixes in the release 927
#370 Post by Marek » 01.04.2025, 09:51
- Bug fix: Selection in the first tab may be lost after switching to second tab and back
- Bug fix: Keyboard Shortcuts disappear if "Allow rename on slow double click" is off and you try to rename folder in the tree per slow double click
- Bug fix: Favorites may be lost if an error occurs while saving - now the old file is loaded again
- Bug fix: Shorted file name with ellipsis at the end may be to short if extension is not showed in the caption and file name contain dots
- Bug fix: Searching for text in PDF files with password may result in exception
- Bug fix: fc7Zip plugin - file list is empty for encrypted files
- Bug fix: "Copy folder path to clipboard" for plain view - full path is copied and not only directory path
- Implemented: Paste operation (tree and file panel) is performed in non blocking mode
- Implemented: Drop operation is performed in non blocking mode
- Implemented: Double click on the tree node - refresh node
- Implemented: Search dialog - new filter option "Accept only items with full path length:"
- Implemented: Attribute/Timestamp dialog - button "Copy to clipboard" added for target folder
- Implemented: FTP - new options for transfer added "TLS 1.1" and "TLS 1.2"
Important changes and bug fixes in the release 928
#371 Post by Marek » 04.04.2025, 21:35
- Bug fix: Drag&drop operation partially broken
- Changed: Search form - Encoding selection field is always visible, the value is saved and restored
Important changes and bug fixes in the release 929
#372 Post by Marek » 11.04.2025, 21:57
- Bug fix: Drag&drop operation still partially broken
- Implemented: Tools->Settings->File/folder operations->Darg&Drop: External tool is used for drag&drop (e.g. TeraCopy)
Important changes and bug fixes in the release 930
#373 Post by Marek » 15.05.2025, 21:06
- Bug fix: Create checksums always says "1 Error(s)" with no errors
- Bug fix: Quick viewer, option "After open file - set focus to quick viewer" is not considered for PDF files with multiple pages and visible pages panel
- Bug fix: FC non blocking drag&drop - fail if drop file+folder
- Bug fix: FC non blocking drag&drop - fail on drop to ".."
- Bug fix: When switching the view to one panel and back (F10), the quick view is not opened, although it was visible before switching
- Bug fix: Tree size may change if the form state changes from maximized to minimized and back and the option "Auto resize for main splitter changes" is active
- Implemented: Quick filter - new switch added '\-' for ignore folders
- Implemented: Auto selectable views - it is possible to define filter in the view definition
- Implemented: Viewer - zoom-in selected area: Spacebar+select area
- Implemented: Viewer - fit to window: double click left mouse button
- Implemented: Shift+Click on Delete button in toolbar -> permanent deletion preset
Important changes and bug fixes in the release 931
#374 Post by Marek » 17.05.2025, 18:31
- Bug fix: An exception occurs when clicking the Delete button in the functions bar
- Bug fix: Drag&drop file in the same folder ends with error message
Important changes and bug fixes in the release 932
#375 Post by Marek » 01.06.2025, 21:47
- Bug fix: Double tap on the touch screen is broken
- Implemented: Workaround for Microsoft bug in Windows 11 (version 24H2 Build 26100.4061) - After starting the program, the copy progress dialog is visible during the first copy, but it disappears afterward, but the operation is performed. Please check: https://freecommander.com/forum/viewtop ... 915#p43915
Locked
Users browsing this forum: Bing [Bot], Google [Bot] and 670 guests
