Access Violation error message / non-existing paths
Posted: 22.04.2008, 23:53
When closing a non existing folder (e.g - the host computer is offline), the following error message is shown:
"Access violation at address 00472143 in module 'FreeCommander.exe' Read of address 000001B4."
edit: there is a general problem when loaing FreeCommander with non-existing directories tabs. e.g. - if you used a remote share or UNC such as \\192.168.1.1\c$, then locked the tab, then closed FC, then disconnected the remote computer and finally re-loads FC - you'll have access violation and FC won't function correctly. It is also impossible to close FC with the X or alr-f4. You must use task manager. It seems that only the pane with the non-existing paths is affected.
edit: it will be possible to "re-birth" FC (as you can't work with it anymore after the above) by editing the init file (freecommander.ini) and delete all non-exisiting entries from affected panes.
FC shoul be able to disable such tabs or enable refreshing un-reachable paths so the user can know if it is available or not.
