fcZip
Posted: 12.02.2017, 15:32
I cannot make internal zip packer make work properly:
1) even tho it says it has 607 supported options such as "Can modify archives", I cannot add/remove anything to a ZIP archive
2) [feature request] when creating archive using ctrl+f5, would be good there's a folder name zip extension prefilled and target folder is the another panel with files, because it's similar operation to copy (f5) which copies selected file(s) to second panel
if there's another plugin that can handle this, please let me know
