"Change case" niggle
brundle
#1 Post by brundle » 24.04.2008, 20:35
I use FC all the time, but even the beta version does what I'm posting about; When you choose Change case, Mixed, Files and you want to rename MP3 or music files, FC makes any character after an open bracket lower case, but the rest of the characters inside the brackets upper case, example; "perpetuous dreamer - the sound of goodbye (armin van buuren basic instinct remix).mp3" becomes
"Perpetuous Dreamer - The Sound Of Goodbye (armin Van Buuren Basic Instinct Remix).mp3".
Yeah, I know it's not the end of the world, but it would save having to use a different app for case renaming...
Also, is there way to get FC to go to the root of a drive every time it's accessed instead of the folder you last used on that drive?
Mar2zz
#2 Post by Mar2zz » 24.04.2008, 22:37
Answer to your 2nd question:
Go to settings, view, drives: choose root folder
Users browsing this forum: No registered users and 14 guests
