Renaming to upper/lower case does not work on USB-drive
Posted: 04.05.2017, 17:28
- Have a USB-drive with FAT32 partition
- Have a file abc.txt
- Rename it to ABC.txt
- Press Enter
Expected result:
File should be named ABC.txt afterwards
Actual result:
It is still abc.txt.
Workaround:
Rename the file to "xABC.txt" and delete the x in a second rename.
Problem does not show up on a fixed harddrive with NTFS file system.
FreeCommander XE 2017 Build 745 64-bit donor
Windows 10, 1703 "Creators Update"
- Press Enter
Expected result:
Actual result:
Workaround:
