ZIP refresh
Posted: 27.04.2008, 23:10
ZIP file contents wont refresh on DRAG AND DROP operation. It will only work with F5 or SHIFT-F5.
When using drag and drop, you must change directory (e.g. - "go up" button" and then re-enter the directory where the file/s were dragged.
