Page 1 of 2
763 Hot item color
Posted: 06.12.2017, 12:47
by alf5000
In NC-mode there is a VERY irritating hot item color bug.
look at this - all items are selected but display is very misleading!
here are the settings:
Re: 763 Hot item color
Posted: 06.12.2017, 22:29
Try to disable the options on the General tab:
[ ] Theme off
[ ] Use Windows colors
Posted: 07.12.2017, 12:16
by alf5000
@dreamer
thanks, works perfectly!
but nevertheless, seems to be a bug - you found a workaround
Posted: 08.12.2017, 01:18
I'm not sure, it's a Windows/Explorer feature, which probably can't be controlled by FC, perhaps "Use Windows colors" option should be always disabled if NC mode is enabled.
Posted: 11.12.2017, 12:03
by alf5000
Dreamer wrote: 08.12.2017, 01:18 I'm not sure, it's a Windows/Explorer feature, which probably can't be controlled by FC, perhaps "Use Windows colors" option should be always disabled if NC mode is enabled.
ok, I guess you're right: it's not a bug - but it is definitely not very intuitive.
Posted: 11.12.2017, 12:07
by alf5000
found another strange thing:
Posted: 11.12.2017, 16:17
by alf5000
settings above also lead to this:
Posted: 11.12.2017, 22:13
Are you sure it's with those options? Some options are not changed if you don't use the Apply button.
Please try to restart FC and default settings.
Posted: 11.12.2017, 22:29
There is also Windows in the game.
On Windows 10 seems to be ok.
Posted: 11.12.2017, 22:38
by alf5000
Dreamer wrote: 11.12.2017, 22:13 Are you sure it's with those options? Some options are not changed if you don't use the Apply button.
yes, sure.
Posted: 12.12.2017, 00:15
by alf5000
Marek wrote: 11.12.2017, 22:29 There is also Windows in the game.
Tested on Win10:
FXCE_762 is ok.
FXCE_763 and later are not ok.
Posted: 12.12.2017, 01:10
Please test with default setting + change those options on screenshots.
How to report a bug
Or/and you can send the ini file to Marek via email.
I can't reproduce with 764 64-bit donor, Windows 10 Home 64-bit.
Posted: 12.12.2017, 11:59
by alf5000
try this FreeCommander.ini https://www.dropbox.com/s/n26edriqiwrwz ... r.ini?dl=0
and hover your mouse over "Focused item active list" for about 0,3sec.
Posted: 16.12.2017, 21:07
by alf5000
765 didn't change anything for the better
perhaps it helps you to know, that there is a very faint dotted line starting at the end of the name column (it's almost invisible, but if you have a very close look you will see it)
sorry for large images.
Posted: 31.12.2017, 14:38
by alf5000
either nobody else is using NC-mode or nobody else minds broken color system of FCXE in NC-mode :?:
as soon as I use NC-mode in details list view colors are not correct - no need to change any of the default color settings.
e.g. selected files are not displayed in red text when mouse hovers over them.
(tested on a vanilla new FCXE portable 767, Win10x64 & Win7x64)
