Tab navigation
Posted: 07.02.2018, 10:47
by JW01
Is there a shortcut key to navigate between tabs within the same pane?
Re: Tab navigation
Posted: 07.02.2018, 13:24
by alf5000
default shortcuts:
Ctrl+Tab
Shift+Ctrl+Tab
you can reassign these shortcuts to your personal preferences
Re: Tab navigation
Posted: 07.02.2018, 16:58
by JW01
That's great. Many thanks.
