Re: Optimizing FreeComm vertical space ...
Posted: 02.04.2018, 14:45
1. Could you be more specific, perhaps show some screenshot(s)? It is possible to hide main menu, main toolbar, drive bar and use vertical toolbars, non just splitter.
2. Currently it's impossible to hide the tab-bar AFAIK, but if you don't use tabs, you can hide it:
http://freecommander.com/en/faq-folder- ... ideTabArea
Posted: 21.04.2018, 04:00
by AEN007
Dreamer wrote: 02.04.2018, 14:45
drive bar and use vertical toolbars, non just splitter."
Hello ...
I'm posting two images ...
They show the minimum height to which I can re-size FrC XE 2018:
I show ~ by comparison ~ how flexible 2xExplorer is ...
as far as vertical resizing ...
2xEx can even be resized down to just the WindowTitleBar ...
In any case ... I find that FrCXE would be "better" ...
if I could resize the VerticalHeight more than FrCXE currently allows ...
Thanx ... however ...
I DO use tabs ...
I just don' t need to see any of the TabArea ~
which (therefore/imo) is VerticalSpace that could be more efficiently used ...
I use the TabPopUp menu to switch tabs ~
which (in my config) are grouped by DriveLetter ...
Posted: 22.04.2018, 21:18
OK, so #2 is to hide tab bar, perhaps it could be added, Marek must decide, but it's possible to hide drive bar, menu, toolbars, splitter, so perhaps it's possible...
Posted: 30.04.2018, 20:29
AEN007 wrote: 21.04.2018, 04:00
That's about right- I also cannot shrink it more. [Although I do no need it, as 99.99% of the time I use FC in a maximized mode]
Posted: 29.07.2018, 00:32
by AEN007
Hello ...
If I were to make a donation,
would that increase the odds of seeing
my request/s about changing/improving
FreeComm's vertical resizing capabilities implemented
FrC's current (lack of) vertical resizing capabilities
REALLY make FrC feel ... CUMBERSOME ... to me
Posted: 29.07.2018, 11:52
Define in the freecommander.ini
[Form]
MainFormMinH=100
Posted: 04.08.2018, 05:36
by AEN007
Marek wrote: 29.07.2018, 11:52
[Form]
MainFormMinH=100"
Hallo
, Marek ...
und vielen Dank ... für alles ...
Ich habe gerade im Juli(2018) mein erstes Win7x64 "installiert" ...
Ich möchte jetzt/auch FrCx64 ausprobieren
Posted: 19.08.2021, 13:44
by AEN007
[Form]
MainFormMinH=100
Greetings, (Earthlings)
I just updated to:
FreeCommander XE 2021 Build 850 64-bit donor
and the above tweak (seemingly???) no longer works
Please reply/advise
Posted: 30.08.2021, 21:18
Yeah, thanks
