[Solved] Favorite Tool Bar Configuration Window too small and placement of tool bar difficulty
Posted: 05.06.2018, 09:36
I took a look at the discussion request: copy folder structure
I decided to try out François' suggestion and noticed that the window to create a new program favorite is too small, see picture below.
After creating the favorite tool bar, I cannot place it next to the standard tool bar. It is only allowed to place it underneath, which takes away screen real estate, see picture below
Thanks for your help, best regards
Ete
FreeCommander XE 2018 Build 775 64-bit donor
Windows 10 Pro 64-bit Version 1803 Build 17134.81
Ete
