Operations on Search File/Folders results
Posted: 23.05.2008, 21:20
It would be great if the Results screen would allow any operation that's possible in Windows Explorer.
Examples...
When I perform a Search for, say, *.txt files on drive C:, the standard Windows right-click menu (Send To, etc) is not available in the Results screen. It would be useful to allow the same Windows context menu that's available in the FC panels.
Also, is there a way to allow a person to highlight and then drag/drop any of the files in the results window to another location? All I can do now is highlight a file and display it in a panel, so it's not possible to move or copy all the located *.txt files to drive D:.
Thanks.
Examples...
Thanks.
