Need help with QuickView for Office and PDF files
Posted: 27.05.2008, 07:20
First, let me say that I am a VERY happy FC user --- I keep discovering features and tricks, this is wonderful software!
FC QuickView displays beautifully my html, mht, text, videos, most graphic files, plays my music tracks. Is there a way to get it to show my Word, Excel, OpenOffice, and Pdf documents in the right-hand pane?
I have read at least 10 forum threads about QuickView, FileView, and using Lister plugins, and haven't had any luck finding a solution.
I'm on XP Pro SP2, using FC v 2007.10a installed and configured for portable use on my external usb hard-drive.
I installed / configured Office.wlx and Pdfview.wlx in both the Internal and External viewer configuration dialogs. (and am not happy that PdfView.wlx requires installation of 20 MB Ghostwriter-AFPL ---can't use the GPL version I already have!)
I tried installing the MS converter pack *.cnv files to the default directory C:\Program Files\Common Files\Microsoft Shared\TextConv.
I tried placing the plugins and converter files in a "Plugins" folder in the FC directory, and then tried putting them all directly in the main FC directory alongside FreeCommander.exe.
When I try to use QuickView to display Word, Excel, OpenOffice *.odt or PDF documents in the right hand pane,
AND
when I use File View / File Edit (both the FC internal viewer, and when set up to use "external" ATViewer) ----
The pane or the "viewer" window displays "Web page unavailable offline", and then launches the associated app and opens the file in that.
This isn't what I was hoping for ---- if I wanted to open Excel or Word, I would just double-click to open the file normally. I want to just view the file, not edit it.
Am I misunderstanding how QuickView works?
Is this just the way FC operates, or am I doing something wrong?
Thanks in advance for any advice ---
granny
AND
granny
