file copy name
Posted: 03.06.2008, 17:46
Since the Free Commander is so quick on the updateing of a folder...
performing a copy of a file into the SAME directory, produces the standard MS name of 'Copy of ...'
But this immediately sorts to the 'C's in the list, and for a big folder, this means one has to go hunt for the copy just made.
If the new name is set to something like
originalname COPY
originalname COPY(2)
then it would at least be right there with the original file that was just copied (yes, if sorted by name)
originalname COPY
