Tree Display Glitch
Posted: 10.10.2018, 14:44
Hi Marek,
I've been using FreeCommander for over a year without issue. Today, it seems it is glitching out with respect to the file Tree. I do not believe there was a Windows update that instigated this so this surprised me. Originally, I thought it was related to network drives, but it can access them without issue, it is only when viewing the Tree.
I have tried:
- uninstalling and reinstalling. No solution. It kept the INI settings file.
- I deleted the INI settings file and re-opened and the tree view was disabled, so it looked ok, until I enabled the tree view.
- I uninstalled and installed the 780 beta and this also did not fix it.
- It is also related to opening any directory tree, such as searching for the folder for the settings file.
I'm running:
Intel Xeon CPU Ee-1505M v6 @ 3.00GHz
Ram 32 GB
64-bit OS, x64 based processor
Windows 10 Pro
Version 1803
Installed on 7/10/18
OS build 17134.165
Thanks,
Ken
I have tried:
I'm running:
Ram 32 GB
Windows 10 Pro
Version 1803
OS build 17134.165
Thanks,
Ken
