Recycle Bin Context Menu
jjcamilli
#1 Post by jjcamilli » 13.10.2018, 16:41
I am getting the following in the recycle bin context menu:
A-ffnen mit FreeCommander
I am not using Germany language
Any suggestion?
Re: Recycle Bin Context Menu
#2 Post by Dreamer » 13.10.2018, 20:18
Which version are you using - and which OS (Windows)? I don't have this item in FC 784 64-bit portable version, Windows 10 64-bit.
"Mit" is "with" and the only item with "FC" is "Open with FreeCommander", so it's probably this item.
jjcamilli
#3 Post by jjcamilli » 14.10.2018, 05:03
Windows 10 1803 build 17134.345
FreeCommander XE 2018 Build 784 64-bit donor
#4 Post by horst.epp » 14.10.2018, 16:04
jjcamilli wrote: 13.10.2018, 16:41 I am getting the following in the recycle bin context menu:
Any suggestion?
Not a solution but a suggestion:
There is never a need for using the context menu of the recycle bin.
So just ignore this entry.
Windows 11 Home, Version 25H2 (OS Build 26200.9168)
Everything Version 1.5.0.1422b (x64), Everything Toolbar 3.2, Listary Pro 7.0.0.9 beta
jjcamilli
#5 Post by jjcamilli » 14.10.2018, 19:02
I agree was just curious
Users browsing this forum: No registered users and 34 guests
