770a 64-bit donor crashing in Win10 Pro/ v. 10.0.17134
Posted: 15.10.2018, 01:22
by rdd2
Hi -
770a 64-bit donor simply will not stay open in Windows 10 Pro / v. 10.0.17134 (Build 17134).
I open Free Commander. It stays up for a few minutes and then spontaneously closes.
Thanks - Ron
Re: 770a 64-bit donor crashing in Win10 Pro/ v. 10.0.17134
Posted: 15.10.2018, 13:15
Posted: 15.10.2018, 14:12
by rdd2
I hadn't tried 780 beta. So far it seems to be holding, after an hour. Thanks - r
Posted: 20.10.2018, 01:42
by rdd2
After a few days, I encountered the same problem with 780 beta. It would not remain stable, and shut down spontaneously after a few minutes. I reinstalled Build 783 64-bit donor which had been stable before the 17134 build of Win10 Pro. But it is showing the same bug. It stays open for a few minutes, behaves properly, and then disappears.
Posted: 21.10.2018, 16:53
I use FC on Win 10 17134 all the time without problems.
Have you checked Windows event logs?
Posted: 21.10.2018, 17:00
by rdd2
Thanks for your reply. I have checked the event logs. There are logs of the crashes, but I'm insufficiently skilled to know how to make use of the information.
Posted: 21.10.2018, 17:10
You can select some lines in the event log and use right mouse click. From the popup menu you can use "save as.." for saving protokoll.
This protokoll you could send to me.
Posted: 21.10.2018, 17:30
by rdd2
Thanks again for your reply. I have emailed you at the info address 2 event logs (in evtx and txt formats) for Event sources 1000 and 1002 related to FC.
Posted: 21.10.2018, 17:50
I can see from the protokoll - all programs crashes on your system. It is not FreeCommander problem.
Probably your Windows intallation is not ok.
Posted: 21.10.2018, 17:56
It seems that you have some problem with ucrtbase.dll.
Many people have problems with it.
Search the web for "ucrtbase.dll error".
Posted: 21.10.2018, 18:08
by rdd2
Thank you for the feedback. I will follow up as you suggest.
Re: 770a 64-bit donor crashing in Win10 Pro/ v. 10.0.17134 FIXED
Posted: 22.10.2018, 04:16
by rdd2
I ran System File Checker tool (SFC.exe), and it found and corrected a corrupt file. FC is running smoothly now.
