BUG 800 - RMB and close all folder tabs and always keep one tab open option
Posted: 10.07.2019, 23:12
- RMB in the empty area above the Address bar
- and close all folder tabs
- with always keep one tab open option enabled
- I'm left with 0 tabs open after this command when it should retain 1 on both sides also if this checkbox is enabled.
