Currently I have Irfanview set up to view DXF files. Is there a way to set FC XE to view these files in the quick view panel? If so, how do you configure FC XE to do this? I've played around a bit in the settings > programs options but haven't been successful.
Viewers
Re: Viewers
Try this plugin: http://www.totalcmd.net/plugring/CADView.html
I don't have a .dxf file to test, sorry.
Edit: found an example .dxf file here: http://dxfgraphics.net It works fine, but the plugin is shareware.
Re: Viewers
Thanks, I'll give it a try. Are there instructions anywhere on how to configure these plugin viewers in FC?
Re: Viewers
Don't know of any official guide...
Open the viewer File\View (F3).
In Viewer go to Options\Settings (F9).
In Configure viewer window activate Plugins tab.
There you can add, delete, edit and establish plugins priority.
Re: Viewers
Thanks, I got it working.
Users browsing this forum: No registered users and 57 guests
