FTP connection fails to save
michal
#1 Post by michal » 07.05.2016, 18:11
If I want to save new FTP connection and save it the following message appears (FC makes no attempt for connection actually).
So I can only establish the connection through Connect button but it does not save the connection then.
FreeCommander XE 2016 Build 720 64-bit donor on Win10 Pro
Re: FTP connection fails to save
#2 Post by Marek » 07.05.2016, 18:17
It is a bug, fixed for the next release.
Workaround: please use only ASCII characters in the connection name.
michal
#3 Post by michal » 26.05.2016, 23:17
Solved with release 723. Now I can see the list of connections (they were actually saved but not displayed).
Users browsing this forum: Amazon [Bot] and 24 guests
