Windows title bar is missing
leeij
#1 Post by leeij » 19.09.2016, 07:10
I use:
FreeCommander XE 2016 Build 715 32-bit public
under Windows 7
I can not found the Windows title bar
(FC with title bar should look like this)
https://drive.google.com/open?id=0B1rK4 ... 2EyRjhTazA
(title bar missing)
https://drive.google.com/open?id=0B1rK4 ... mZnbWV3dGM
while executing FreeCommander. Can somebody help me?
Re: Windows title bar is missing
#2 Post by Karol » 19.09.2016, 07:55
Try View->Full screen (F11).
leeij
#3 Post by leeij » 19.09.2016, 08:03
thanks, it works!!!
Karol wrote:Try View->Full screen (F11).
leeij
#4 Post by leeij » 21.09.2016, 04:25
Forgot to say, even if the above method is working, but every time I execute FC, I have to clck F11 to make title bar come back because it is started WITHOUT title bar. Is there any setting to make it starting WITH title bar?
joby_toss
#5 Post by joby_toss » 21.09.2016, 14:00
After the title bar is displayed, hit Tools->Save settings (or make sure the option Auto save settings - on exit is checked).
or
Close FC; open the FreeCommander.ini file and search for the FullScreen=1 string in the [FcFormMain_State] section; change the value to 0 and save the file.
Users browsing this forum: No registered users and 293 guests
