Pictures open in GIMP instead of default viewer
Rvo
#1 Post by Rvo » 04.04.2017, 17:36
Windows 10 64bit, FreeCommander XE 2017 build 743 (64 bit)
When I double click / press enter on a picture (jpg png) FreeCommander opens it with Gimp?!
There is not text "gimp" in any of the FC ini files.
When I double click / press enter on a picture in Explorer it opens in the default editor
Reinstalled version 742 (64 bit) problem solved
Timon
Re: Pictures open in GIMP instead of default viewer
#2 Post by Timon » 04.04.2017, 18:14
Your problem is similar to viewtopic.php?f=7&t=7859
#3 Post by Dreamer » 04.04.2017, 22:28
Please try the new version 744.
Topic closed, please reply here, or start a new topic if you still have a problem.
Users browsing this forum: No registered users and 222 guests
