FreeCommander frozen when multirenaming 1000 files
jack6th
#1 Post by jack6th » 07.03.2020, 06:49
FreeCommander XE 2020 Build 810a portable ZIP, Windows 10 64-bit 1903
reproduce:
1. Press Win+r -> cmd
input lines below
cd Desktop
mkdir new
for /l %i in (1,1,1000) do @copy NUL new\%i.txt
1000 files are in new dir on the desktop.
2. Open FreeCommander -> go to new dir -> select nothing or Select All -> File -> Multirename
The multirename window is opening but cannot finish. FreeCommander is frozen.
Re: FreeCommander frozen when multirenaming 1000 files
#2 Post by Marek » 07.03.2020, 10:11
for /L %%I in (1,1,10000) do type NUL >"new\%%I.txt"
Tested with 10000 files - no problem.
jack6th
#3 Post by jack6th » 08.03.2020, 00:51
I tested with Double Commander multirename tool - no problem.
And I tested with FreeCommander on another Windows 7 32-bit PC - has this problem too.
Screenshot:
jack6th
#4 Post by jack6th » 30.09.2020, 23:56
New version fixed it.
FreeCommander XE 2020 Build 830 32-bit public beta
Users browsing this forum: No registered users and 5 guests
