Show number of all files in columns - based on the content of all of the subfolders
#1 Post by Forez » 24.03.2018, 13:45
I would like to be able to see in Columns a number of all of the files. But the counting should be performed all the way to the very last sub-folder
For example:
Level 1: Folder "A" has 1 file and a sub-folder "B"
Level 2: Sub-folder B has 1 file and a sub-folder "C" plus a sub-folder "D"
Level 3: Sub-folder "C" has 10 files while sub-folder "D" is empty
And so, when looking in detailed view mode at folder "A", I should be seeing the total number of files which is 12. [And when going into it "B", I would see that "C" has 10 files and "D" has 0]
Re: Show number of all files in columns - based on the content of all of the subfolders
#2 Post by Forez » 07.04.2018, 16:18
And I would also like to point out that this function is kind of already there- at least the behind the curtain mechanism
Because FreeCommander has that three different kind of Plain View options. So all is now missing is an option to show just the numbers representing the content that currently can be shown with all these Plain View options
#3 Post by Forez » 06.07.2023, 20:06
I would like to kindly bring to attention this old idea of adding a possibility for displaying in a Column the total number of files from all of nested sub-folders
#4 Post by horst.epp » 06.07.2023, 20:16
The basic info is not there.
Plain view is created at demand and searches down the tree at your request.
Displaying such info in a column would need a scanning on every folder change.
Windows 11 Home, Version 25H2 (OS Build 26200.8875)
Everything Version 1.5.0.1416b (x64), Everything Toolbar 2.4.1, Listary Pro 7.0.0.0.3 beta
FreeCommander XE 2026 Build 951 64-bit donor
#5 Post by Marek » 06.07.2023, 21:02
That was implemented a long time ago:
- in the Detail View add the FreeCommander column Files
- in the definition of the Detail View activate the option "All subfolder levels for columns: Files, Folders, Items"
#6 Post by Forez » 09.07.2023, 13:33
horst.epp wrote: 06.07.2023, 20:16 The basic info is not there.
I see no problem with that- as long as that
indication is retained for marking those folders which are still being processed
What I do have a problem with is the concept of being able to apply this option only a profile-by-profile basis, thus each time having to go to
Tools > Settings > View > Column profiles/automatic views > Column profiles [TAB] > [SELECT A PROFILE] > Define columns [ICON] > All subfolder levels for columns: Files, Folders, Items
in order to turn it ON and OFF. It took me a while to find it and I must had stumbled upon it in the past, when I was creating [at least my main used daily thus sometimes updated] Profile- and yet it did not clicked in my head that this was the option I was longing for
Hence, as my empirical example shows, this should be:
● more easily accessible
● named in a more informative way
● applicable to all
Thus I propose adding a check-box option like
Tools > Settings > View > Count files and folders from all subfolders when using view with Columns
or at least
Tools > Settings > View > Column profiles/automatic views > Show number of all items from all subfolders when using Columns
If such change is implemented then the existing option should be removed - or could be changed to
Tools > Settings > View > Column profiles/automatic views > Column profiles [TAB] > [SELECT A PROFILE] > Define columns [ICON] > Override the "Count files and folders from all subfolders" option (if selected)
Alternatively this existing option could be removed- and instead of that its function be accessible by selecting
Tools > Settings > View > Column profiles/automatic views > Column profiles [TAB] > [SELECT A PROFILE] > Define columns [ICON] > Add new column [PLUS ICON] > FreeCommander [SECTION] > Items from subfolders
which would be a complementary to ordinary
already available there
Users browsing this forum: No registered users and 164 guests
