The English translations of FC strings are usually very accurate and clear, but some could be tweaked.
4602=The file name contains not visible characters typical for malicious software (virus).
Change "not visible" to "invisible"
6012=Destination device is full and happens to be removable
Change "happens to be" to "is"
50052=Target object does not exists or can not be opened!
Change "exists" to "exist"
54045=If recycle bin property "Don't move file to the recycle bin. Remove file immediately when deleted." is active - delete operation is permanently.
Change "permanently" to "permanent"
56276=Archiver plugin not found or the file can not be handle (e.g. password protection)
Change "handle" to "handled"
58614=Path is not defined or can not be find!
Change "find" to "found"
59024=The calculated sum is not equal with the pattern sum:
59025=The calculated sum is equal with the pattern sum.
Change "with" to "to"
61040=Count of lines in the file (%s) does not match with count of files in the list (%s)!
Delete "with"
66512=Files which exists only on the right:
69102=Do you want to temporary download the file?
Change "temporary" to "temporarily"
In several places, "canceled" should be changed to "cancelled"
6001=User canceled entire job
6002=System canceled entire job
69748=Operation canceled
70312=Function was canceled by the user
There are several places where "can not" should be grepped to "cannot"...
67002=Can not create target folder:
67004=Can not auto rename "%s"
69756=Can not rename target file: %s
57063=Can not auto rename "%s"
58213=Can not find installed VLC Player (www.videolan.org)
Hope that helps
English.lng tweaks
Re: English.lng tweaks
Good catch.
There are a lot od "exists" instead of "exist".
Thanks, the changes are integrated in the release 910.
Users browsing this forum: No registered users and 51 guests
