Build 932 Thumbnails for folders look strange
sebbo76
#1 Post by sebbo76 » 05.06.2025, 18:40
Thumbnails for folders look strange. The thumbnails look like GIFs. It used to look better. I'm using the latest donor version Build 932. Bug?
Re: Build 932 Thumbnails for folders look strange
#2 Post by horst.epp » 05.06.2025, 19:51
Looks fine here with the same FC version.
Windows 11 Home, Version 26H2 (OS Build 26300.9550)
sebbo76
#3 Post by sebbo76 » 05.06.2025, 20:36
Thanks Horst, but I also see artifacts in your thumbnails. The larger the thumbnails, the better they look. At 120 pixels, they look like mine. At 256 pixels, the quality is normal.
#4 Post by horst.epp » 06.06.2025, 15:45
sebbo76 wrote: 05.06.2025, 20:36 Thanks Horst, but I also see artifacts in your thumbnails. The larger the thumbnails, the better they look. At 120 pixels, they look like mine. At 256 pixels, the quality is normal.
You have to click into the picture
to get the correct display.
My settings are 192
sebbo76
#5 Post by sebbo76 » 06.06.2025, 16:51
Set the thumbnailsize to 120 and you will see the artifacts.
#6 Post by horst.epp » 06.06.2025, 17:28
sebbo76 wrote: 06.06.2025, 16:51 Set the thumbnailsize to 120 and you will see the artifacts.
Not for me.
I can use many of the smaller and larger sizes than 192, without getting bad displays.
It's a matter of scaling and also depends on your screen resolution and graphic driver functions.
My screen is 1920 x 1080
Users browsing this forum: Amazon [Bot] and 29 guests
