822 - Tooltip alignment issue
Posted: 13.06.2020, 18:46
If the FC window is on the bottom right corner, it's small and the file name can't be fully shown, tooltip is partly cut off / off screen.
In Details and List view.
In Explorer the tooltip is moved a bit left, so it can be shown correctly.
FC 822, Windows 10 1909.
Re: 822 - Tooltip alignment issue
Posted: 17.06.2020, 06:51
by Odamn-Ete
cannot confirm,
on my system the tooltip is displayed over the FC UI, no cut off
FreeCommander XE 2019 Build 822 64-bit donor
Windows 10 Pro 64-bit Version 1909 Build 18363.900
Maybe it has to do with your color scheme? I don't use them.
note: in Windows Explorer it is the same, i.e. the tool tip is displayed over the UI, not within it
Posted: 17.06.2020, 20:18
You need to disable the option in Settings > View > File/folder list > General > Show files and folders tooltip.
Then test with long names in small FC window in bottom-right corner, or move the splitter right, so the file name is not fully visible.
Posted: 18.06.2020, 06:41
by Odamn-Ete
Dreamer wrote: 17.06.2020, 20:18
... disable the option in Settings > View > File/folder list > General > Show files and folders tooltip.
Dear Dreamer, I followed your instructions and the behavior is the same as described above, i.e. the tooltip is displayed over FC UI and there is no cutoff
Best regards
Posted: 18.06.2020, 21:14
Strange, I tried with default settings, another screenshot.
Posted: 19.06.2020, 05:40
by Odamn-Ete
Dear Dreamer,
thanks for posting the last screen shot. In my previous testing I overlooked the notice "in lower right corner of the screen (display)". Now I can confirm your issue.
In Windows explorer the tooltip is moved left to be able to be completely shown, in FC the tooltip is NOT moved left and therefore cut off.
best regards
Posted: 23.06.2020, 04:53
by Odamn-Ete
Cannot confirm
see here for details
Can confirm, file name caption is not aware of screen/display boundaries. When file names are so long that at the end of the name <...> are shown and the mouse cursor is hovering over the name AND FC is moved past the borders of the screen/display/monitor the file name caption is cut off.
File Name Caption, FC fully viewable on the screen.
File Name Caption, FC moved right passed the borders of the screen (not fully viewable).
