829 - Focus newest/previous/next position issue
#1 Post by Dreamer » 18.09.2020, 23:51
First, thanks for this new feature, it will be really useful.
However, it does not work good.
- use default settings, probably not needed
- assign the keyboard shortcuts for all 4 new functions Focus newest file / newest item / previous item / next item
- go to folder with many subfolder, files, or/and use a small FC window, scrollbar must be visible
- use list view, or/and details view
- use the keyboard shortcuts to go to previous/next/newest item (or newest file)
= column/position is not updated if the target item is not visible in the active panel
FC 829 64-bit donor, Windows 10 2004 64-bit.
Re: 829 - Focus newest/previous/next position issue
#2 Post by Dreamer » 19.09.2020, 00:57
Workaround - if you want to use it before fix - press up and down arrow keys in list/details view, or left/right in thumbnails view.
petar_1970
#3 Post by petar_1970 » 18.10.2020, 22:42
First of all, thanks for a great feature - it's very useful.
I have a question regarding this.
I expected that "focus previous/next item" will jump to previous/next item by last access timestamp, not to previous/next item in the folder.
I mean, when I jump to the newest item, I can simply go to the previous/next items using arrows - it wasn't needed new action for this.
Do I miss something?
#4 Post by Dreamer » 18.10.2020, 23:58
petar_1970 - "focus previous/next item" work good, it was added for different purpose, if you need to show more than 1 new item, use sorting by time.
Original bug is fixed now in 831.
Topic is closed.
Users browsing this forum: No registered users and 41 guests
