Menu font size keeps reverting to default
#1 Post by Forez » 05.02.2021, 03:34
Under the
Tools > Setting > View >menu font Size
I can change the size of letters in my menus. In order for it to happen I must close and re-open FreeCommander. I can even multiple times re-open FC, for whatever reason
But if i rest the operating system, my menus are apparently in a default size - despite my chosen value of size still being visible in the aforementioned place
I am using FreeCommander XE 2020 Build 810a 32-bit public on Windows 10 Enterprise 20H2 19042.746
Re: Menu font size keeps reverting to default
#2 Post by horst.epp » 05.02.2021, 12:46
Try with the actual version before you report problems please.
Your version is much to old, current public version is 840.
#3 Post by Forez » 07.02.2021, 18:34
horst.epp wrote: 05.02.2021, 12:46 Try with the actual version before you report problems please.
And so it seems that from 830 onward this bug is gone
And so it seems that also whatever fixed this issue, at he same time it unfortunately created also a new one: https://freecommander.com/forum/viewtop ... 82&p=35282
#4 Post by Forez » 11.02.2021, 18:19
Just to make it clear:
this menu bug is gone now
Users browsing this forum: No registered users and 35 guests
