I set this up before but I forget how.
I think there's a setting in the .ini file that needs to be changed if I'm not mistaken?
SOLVED - Toolbar - How to toggle between thumbnail and details view
Re: Toolbar - How to toggle between thumbnail and details view
No special setting needed.
Just the button "Thumbnails" which toogles between the Current View and Thumbnails.
Default hotkey is Ctrl-I
Windows 11 Home, Version 25H2 (OS Build 26200.9168)
Everything Version 1.5.0.1422b (x64), Everything Toolbar 3.2, Listary Pro 7.0.0.9 beta
That toggles between thumbnails and list view for me.
- If you set the thumbnail view
- Close FC
- Reopen FC
- Use the toggle button.
- It toggles to list view
[Form]
ToggleViews=2,3,5
This option change the shortcut for "Toggle views" (F9 by default), between List, Details, Thumbnails.
I'm not sure about the numbers, 5 should be Thumbnails view, if you want just Details and Thumbnails, use just 3,5.
I'll add it also to the topic "FreeCommander XE "not so obvious" settings".
ToggleViews=2,3,5
Re: SOLVED - Toolbar - How to toggle between thumbnail and details view
You're welcome, try also the Automatic views, it can reduce need to switch it manually (if you're not using it already).
Oh, I did try but I find myself needing to view the same directory differently a lot.
I've only set up some very basic rules for folders that I know I want to view a particular way.
Users browsing this forum: No registered users and 255 guests
