Rename button and shortcut F2 in Viewer
#1 Post by Dreamer » 30.05.2021, 17:01
Could you add Rename action for Viewer, please?
Is there any reason why it's not there? It works in Quick viewer, it's possible to rename a file, also in viewer Delete is possible, but Rename is missing, so I have to close viewer, rename file, open Viewer and then do the same for next files.
Re: Rename button and shortcut F2 in Viewer
#2 Post by Dreamer » 12.06.2021, 22:02
Added in 849, thank you, Marek.
Users browsing this forum: No registered users and 60 guests
