The 849 fix to correct the "broken tree when opening first new tab" only works when "always keep one tab open" IS NOT CHECKED.
However if "always keep one tab open" IS CHECKED, then the first new tab still loses the tree.
I've made two short screen-capture videos to demonstrate. Each video runs through the demonstration TWICE, just to prove that the behavior can be reproduced.
Here is a demonstration of how things now work correctly with the 849 fix, as long as "always keep one tab open" IS NOT CHECKED. The tree is now retained when the first new tab is opened.
But here is a second demonstration of how things are still broken if "always keep one tab open" IS CHECKED. In this case, the tree is lost when the first new tab is opened.
849: Fix for "tree visibility broken" only 1/2 fixed
Re: 849: Fix for "tree visibility broken" only 1/2 fixed
Hey dsperber,
I tested this in FC 850 and it is fixed.
I have "always keep one tab open" checked
and tree view is not lost when opening a new tab
Best regards,
FreeCommander XE 2021 Build 850 64-bit donor
Windows 10 Pro 64-bit Version 20H2 Build 19042.1110
Best regards,
Users browsing this forum: No registered users and 14 guests
