Should Synchronize Directories Default Filter Include Be *.*
Posted: 03.09.2008, 18:41
I noticed that in beta 375, there is no visible default in the FILTER INCLUDE entry. The field is blank.
Should it be showing a default of *.* instead of being left blank?
This function does use *.* by default, is that correct?
I was thinking that if so, it would be good to actually show that *.* in the INCLUDE box by default.
I hope that makes sense. I also hope that I'm not overlooking something and this request is not valid. If so, I'd appreciate your understanding if I did miss that. If not, then hey, life is good.
Thank you.
Thank you.
