I want to use version 2009.02b 'cos I want t/access to twos disks simultaneously.
But I cannot record the preferences.
Can you help ?
I have tried two files: the one downloaded from this Web site, and a copy dated year 2011 which was OK until a fews days...
Any idea ?
How to update the file ini ?
Re: How to update the file ini ?
Could you explain what exactly do you need?
Perhaps you'll find the answer in the FAQ:
https://freecommander.com/en/faq-settin ... s-location
However, the settings of old FreeCommander version 2009.02b or earlier are incompatible with the new XE versions, and cannot be transferred.
Sorry but who can understand this posting ?halt2010 wrote: 21.08.2022, 12:45 I want to use version 2009.02b 'cos I want t/access to twos disks simultaneously.
Can you help ?
Any idea ?
Can you explain in simple steps what you want to do.
Everything Version 1.5.0.1423b (x64), Everything Toolbar 3.3.0, Listary Pro 7.0.0.9 beta
Users browsing this forum: No registered users and 17 guests
