Update find windows file if files are deleted in main program
#1 Post by stephen147 » 21.08.2022, 13:57
As the title suggests.
1. Find a file or folder in the find window.
2. In the main program, delete it.
3. The find windows list gets updated.
Re: Update find windows file if files are deleted in main program
#2 Post by Forez » 23.08.2022, 19:47
Well, it is a common issue in also other programs [e.g. Mp3tag]
But should this, if implemented in FC, should be done automatically? Or as one of the settings a user can choose?
#3 Post by stephen147 » 23.08.2022, 19:54
IMO as a user option, I would say but I think if the file is deleted no then the file cannot be opened or properties can be gained from it so not much point in keeping it.
Users browsing this forum: No registered users and 61 guests
