What happens: you change the language of the UI in the settings. The language of the menu bar is changed correctly, but the shortcut menu of the Favorites pane only changes after restart.
How to reproduce (supposing you have the UI language set to English):
1. Go to Tools > Settings > General > Language.
2. Change the language to French and click OK. The language of the menu bar is now in French.
3. With Favorites pane open, select an item and right-click - the menu is still in English.
4. Restart Freecommander. Now the Favorites shortcut menu is in French.
Version used: FreeCommander XE 2022 Build 880 64-bit donor (portable), Windows 10.
Language settings only partially applied
Users browsing this forum: Bing [Bot] and 2 guests
