884: MP3Tag Context Menu item broken again
m-a-r-k
#1 Post by m-a-r-k » 18.02.2023, 14:49
As title, MP3Tag not showing in context menu again for folders, Windows 11 22H2
It is present on my Window 10 laptop though.
Re: 884: MP3Tag Context Menu item broken again
#2 Post by Forez » 10.03.2023, 14:07
Well, my Mp3tag 3.19 is showing for both files and folders in shell menu on my on Windows 10 Enterprise 20H2 19042.746 x64 when using FC x64 880 and FC x64 885 Portable
Check your shell when using Windows Explorer
m-a-r-k
#3 Post by m-a-r-k » 10.03.2023, 19:49
"Well", I can't say that your response is helpful or pertinent.
This has been a problem before in a previous release.
Marek, MP3Tag 3.19 x86 and x64 both have this problem.
#4 Post by Forez » 11.03.2023, 14:18
How is my report of no value if I have tested your claims it a newer version of FreeCommander and on a much older version of Windows? It shows that it is possible this issue will be gone if you update to FC 885
Have you asked around about this issue on the forum of Mp3tag?
Users browsing this forum: No registered users and 16 guests
