886: Multirename tool doesn't always launch with selected files
etc.
#1 Post by etc. » 31.03.2023, 20:42
If I select some files in Details view, multirename tool will launch with selected files.
But if I select some files in other view (thumbnail, icon, list), multirename tool will launch with whole files in folder.
Re: 886: Multirename tool doesn't always launch with selected files
#2 Post by Marek » 31.03.2023, 20:46
I can not reproduce it.
Do you have steps to reproduce this?
etc.
#3 Post by etc. » 31.03.2023, 21:12
Thank you for testing.
Well it happened many times when I tested last time but I couldn't reproduce this anymore.
I will report if I could reproduce again.
#4 Post by Dreamer » 31.03.2023, 21:27
- select file 2 and 3 of 4 files in folder
- focus [..] item (Ctrl+up or left arrow with default settings, or Home with NC-mode enabled)
- F2
It's a standard behavior, if the focus is on [..] item and F2 is used, all items are selected and added to multi rename dialog.
etc.
#5 Post by etc. » 31.03.2023, 21:57
Ok, it also happened in details view.
My step to reproduce:
1. Open a tab.
2. Click and select on ".." item.
3. Press LMB on empty space and select some files with mouse drag.
4. Select Toolbar/File/Multirename...
#6 Post by Forez » 03.04.2023, 14:36
etc. wrote: 31.03.2023, 20:42 If I select some files in Details view, multirename tool will launch with selected files.
etc. wrote: 31.03.2023, 21:57 Ok, it also happened in details view.
Isn't this another variant of this long time bug of mine: http://freecommander.com/forum/viewtopic.php?p=37001?
#7 Post by Dreamer » 03.04.2023, 18:11
This issue is not a bug, it's a feature - standard behavior.
Moved to Discussion.
Forez wrote: 03.04.2023, 14:36Isn't this another variant of this long time bug of mine: http://freecommander.com/forum/viewtopic.php?p=37001?
I'll reply in that topic.
Users browsing this forum: No registered users and 14 guests
