Small menu bug- DEFINE ACTION TOOLBARS may not show BUTTON SIZE
JMK
#1 Post by JMK » 19.04.2025, 18:25
(This is a very small impact bug, so you may not want to fix it. PS: Thanks for your work on the other bugs I've reported!).
Summary:
In the DEFINE ACTION TOOLBARS, for most of the toolbars you have the option to change the toolbar's BUTTON SIZE.
BUG: If you create an addition toolbar, the BUTTON SIZE option will not be visible until you first click on a different toolbar (such as STANDARD toolbar).
Then the BUTTON SIZE appears and can be adjusted.
Using:
FreeCommanderXE-64-donor_portable929
Windows 10 Home 64-bit 21H2, latest version as of 2025-04-19
Recreate:
Click on TOOLS > DEFINE ACTION TOOLBAR (OK)
(Note that the default selection is ADDRESS toolbar, which has no BUTTON SIZE) (OK)
Click on PLUS and add a new toolbar MyTestToolbar
(you don't have to add any tools to this new toolbar).
BUG: (Note that the BUTTON SIZE is not visible)
Click OK
continuing...
Click on the new MyTestToolbar
SAME BUG: BUTTON SIZE is not visible
(Note that the BUTTON SIZE is now visible)
Now click on on the new MYTESTBAR.
GOOD: Now note that the BUTTON SIZE is now visible.
Workaround:
When invoking DEFINE ACTION TOOLBARS, click on STANDARD toolbar before clicking on a custom toolbar.
Users browsing this forum: No registered users and 154 guests
