[SOLVED] Renaming a file changes display order
Bugs and issues.
jimdunn
#1 Post by jimdunn » 06.10.2025, 22:42
Hi, if I have a folder with say, 100 files, and I rename one of the files near the bottom, it changes the display order... forcing it near the bottom of my window...
I hope you're able to understand/replicate this... it happens if I'm sorting by Name or Modified... the same.
EDIT: Fixed in later versions.
Users browsing this forum: No registered users and 68 guests
