Currently there is available this invaluable option of
Tools > Settings > View > Folder > Folder Tabs > Tab Management > Mark locked tabs with this character
But it can be made even greater - I propose renaming it to
Tools > Settings > View > Folder > Folder Tabs > Tab Management > Mark locked tabs with this character - as prefix
and then adding its doppelganger
Tools > Settings > View > Folder > Folder Tabs > Tab Management > Mark locked tabs with this character - as suffix
i.e. make it possible for user to decide if the marker should be applied in front of the name, after it ends, on or both sides
Locked Tabs prefix feature should be expanded by addition of suffix option
Users browsing this forum: No registered users and 6 guests
