Hi,
it would be great if FC would show a "preview" in the files list, when clicking on a saved profile.
This would make it easier to choose from multiple Rename Profiles.
Regards
Thorsten
"Preview" for Renaming Profiles
Using FC under: Win11 German, Server 2022, Win11 Multisession
Re: "Preview" for Renaming Profiles
Not sure if you mean image preview or name preview, but both are possible now:
To enable image preview, use a toolbar button or Ctrl+Q
To enable new name preview, click to "Auto preview" and select profile in the upper profile field.
However, when you click the profile on the Profiles tab, new name preview is not updated, workaround is double-click, but this will switch to Settings tab, so you have to click to Profiles tab every time. Another workaround is to use the upper profile field.
Actually I do not mean the preview of pictures. I mean the preview of the renaming a profile would do.
