'Configure Viewer' changes are saved but not used until dialog is reopened.
Dr_Eyeball
#1 Post by Dr_Eyeball » 02.01.2026, 01:57
Severity: minor
Build: 939 64-bit donor
Also note that the help page is out of date. This bug report relates to this screen: https://freecommander.com/fchelpxe/en/General5.html
Steps to Reproduce:
  1. Go to:
    Tools (menu) → Settings (menu) → View (tree) → Viewer (tree) → General (tab) → Viewer (button)
  2. Go to:
    General (tab) → 'as Windows preview:' (field)
    But all extension fields are probably affected by this, too.
  3. Add an extension (eg: '.json') to the start of the line.
    .json
  4. Click 'Ok' button
  5. Click 'Apply' button
Problem:
You will find that the change is saved but not recognised.
Work around:
So you need to revisit the 'Configure Viewer' dialogue screen, where you will see the item list is now sorted.
Then click 'Ok' again, and only now will it work and be recognised.
Thanks.
Users browsing this forum: No registered users and 6 guests
