946 (Portable) - I no longer have "press enter to run"
Hi, I updated to 946 last night, and found that "pressing enter to run" no longer worked. I downgraded back to 945 and it worked.
Re: 946 (Portable) - I no longer have "press enter to run"
Could you provide more detailed description what you do, what does not work?
I run FC... I use the arrow keys to cursor down to any MP4 file... I press ENTER... it does not open/run/play...
When I overwrite with 945, I arrow down... press ENTER... and the MP4 plays... (this is Windows 10).
I should also mention that I use "mpv.exe" to run the MP4 files...
Why should FC be responsible for this dialog ?
When you press enter on a local file it should start without any dialog.
Windows 11 Home, Version 25H2 (OS Build 26200.9168)
Everything Version 1.5.0.1422b (x64), Everything Toolbar 3.2, Listary Pro 7.0.0.9 beta
You have defined mpv.exe for all files (filter is *) for external viewer.
External viewer shortcut is Shift+F3.
I think, you shold define mpv.exe in the tab "Default action" with the filter "*.mp4".
Please re-read the 1st command:
(under v945 portable)
When I press ENTER on a .TXT file, notepad opens the txt file with no issues.
When I press ENTER on a .MP4 file, mpv open the mp4 file with no issues.
(under v946 portable)
When I press ENTER on a .MP4 file, NOTHING opens.
And, I did try the "default" tab, same 946 problem...
I also tried both:
--no-input-default-bindings %ActivSel%
--no-input-default-bindings %ActivDir%\%ActivItem%
Same 946 problem.
CORRECTION: When I tried 945 with the "Default action" configured, MPV would not load MP4 files. Once I disabled the "Default action" then 945 works.
I also tried both:
Same 946 problem.
One other note... I have configured "External Viewer" as CTRL ENTER...
And, in 946, when I press CTRL ENTER then the MP4 loads up in MPV.EXE just fine.
What happened to my "ENTER" in 946 ???
Check what happens if you start FC with default settings.
Wow, it was weird... when I started a new instance with default settings, I got:
- pressing ENTER on a TXT file would open in Notepad
- pressing ENTER on an MP4 file would do nothing
- pressing ENTER on a .TS file (a video) would open in Notepad (and look a mess)
I guess I'll just stay with v945.
Could you please send me your settings?
You can save all settings with https://freecommander.com/fchelpxe/en/B ... tings.html
Here is a copy of the settings before I purged all settings and started over a few hours ago.
(these settings worked as expected for ALL file extensions... CMD/BAT/MP4/TS/TXT, etc when run with v945)
Thanks for taking the time...
It appears, with v946, that I have to now specify all movie extensions in "Default action" (see https://postimg.cc/qtD67ZVq)... what I would really like is for FC to just use whatever Windows 10 has associated and run the file with that (notepad.exe with txt, mpv.exe with mp4, etc).
[Form]
Language=english.lng
MainMenuVisible=1
OneInstance=1
MinimizeToTray=0
AlwaysShowSystrayIcon=0
CloseAsMinimize=0
StartAsIcon=0
StartMaximized=0
ShowConfirmationDialogOnClose=0
DeleteHistoryOnClose=1
AutoSaveSettings=1
BkpSettingsFolder=%FcAppDataPath%
BkpSettingsAuto=1
BkpSettingsCycle=1
BkpSettingsMaxSets=5
CheckForUpdateCycle=1
CheckForUpdateShowErrors=1
FilterGlobal=1
FilterAllTabs=0
LastUsedPanel=1
SaveWinERedirect=1
WinERedirect=0
DriveBarType=4
DriveBarAlign=0
DriveBarUseLargeGlyphs=0
ShowFtpAsDrive=0
ShowNetworkAsDrive=1
ShowRemovableOnlyWithDisk=0
ShowNotReadyMsgForDrives=1
HideDisketteDrive=0
SelectCurrentHistoryDir4SelectDrive=0
DriveBtnPopupShowFreeSpace=0
ShowDriveBtnInAddressBar=1
DriveBtnPopupAddEject=0
DriveBarShowProgressBar=0
DrivesBarProgressBarDrawBorder=0
DrivesExcludeList=
DriveNameButtonWidth=100
DrivesShowHint=1
DrivesFreeSpaceForNetwork=0
DriveListFromLogicalDrives=0
TreePosition=0
TreeRoot=0
TreeSplitterHotSpot=0
TreeHotTrack=0
TreeShowHidden=0
TreeShowArchive=0
TreeShowLinkToFolder=0
TreeBigIcons=0
TreeItemHeight=18
TreeIndent=15
TreeSortNodesType=0
TreeAutoResizeWidth=0
TreeAutoScrollSelected=1
TreeShowRemovableWithDisk=0
TreeShowOverlayIcons=0
TreeShowLines=0
TreeFullRowSelect=0
TreeFollowAddrChanges=1
TreePerTab=0
TreePerTabSaveExpanded=0
TreeAutoExpandOnClick=0
TreeControlThemeOff=0
TreeAutoRefresh=0
TreeLoadNetworkNode=1
FavoritesTreePosition=0
FavoritesTreeRelativePosition=0
FavoritesTreeOpenSingleClick=0
FavoritesTreeOpenNewTab=0
FavoritesTreeBigIcons=0
FavoritesTreeItemHeight=18
FavoritesTreeIndent=12
TreeSiteDelayOnStart=100
ViewerPosition=2
ViewerOppositePanel=1
ViewerSplitterHotSpot=0
ViewerUseColorScheme=1
ViewerUseOneInstance=0
ViewerUseSameSettings=1
ViewerFormOnTop=0
ViewerToolbarInViewer=1
ViewerShowLinkTarget=0
ViewerShowConvertedFile=0
ViewerShowIconsInMenu=1
ViewerMouseWheelZoom=1
ViewerShowProgressStatus=0
NetworkUseShellForEnum=1
NetworkCacheServerList=1
NetworkShowHiddenShares=0
NetworkDomains=
NetworkLoadOnPrgStart=0
QuickSearchAutoCloseTime=0
QuickSearchStartOnTop=0
QuickSearchFractionOnStart=1
QuickSearchIgnoreDiacriticalMarks=0
QuickFilterAlwaysVisible=1
QuickFilterAutoWildcards=1
QuickFilterIgnoreDiacriticalMarks=0
QuickFilterOffWithNormalFilter=1
QuickFilterOffWithFolderChange=1
QuickFilterClearFieldOnTurnOff=0
QuickFilterActivateIfFieldNoEmpty=0
QuickFilterKeepOnTabChange=1
QuickFilterClearOnProgramClosing=0
QuickFilterFolderNamesToo=1
QuickFilterEditFieldWidth=60
QuickFilterPositionLeftInRightPane=0
QuickStarterHotkeyGlobal=0
LayoutsAutoSave=0
LayoutActiveId=
LayoutsIgnoreMainWindowSize=0
LayoutsOverwriteWithoutQuery=0
MainWindowTitle=[folder]
SplitterSize=8
SplitterHotSpot=0
GoUpStripWidth=0
ShowGlyphsInMenu=1
ShowMenuHints=0
UseWindowsDrawedMenu=0
DialogsFontUseDefined=0
ColorSchema=FreeCommander_Dark2
ColorSchemaIgnoreFont=1
MenuFontSize=9
IconWithWarningTriangle=1
JumpListIsActive=0
JumpListClearOnClose=1
SortMethod=0
SortDirAlwaysByName=0
SortDirAlwaysOnEnd=0
SortDirLikeFiles=0
SortDirLikeFilesExceptName=0
SortByExtFoldersToo=0
SortShadowColumn=1
SortSamePerPanel=0
ListViewDoubleBuffered=1
ShowHotTrack=0
HotTrackInThumbViewAllowed=0
HoverTime4Select=0
OpenFolderWithOneClick=0
OpenFileWithOneClick=0
FilePanelThemeOff=0
FilePanelRowSelect=1
FilePanelSelectPerDragging=1
NcSelectMode=0
NcSelectExtended=0
NcSelectRightMouse=0
NcSelectSpaceDown=0
SelectLeftClickOnIcon=0
SelectLeftClickOnEmptyCaption=0
NCSelectLeftClickOnIcon=0
NCSelectLeftClickOnEmptyCaption=0
ThumbOpenAndSelectMode=0
ShowHiddenFile=1
ShowSystemFile=1
FileTimeUseDaylightBias=1
ShowExtensionWithDot=1
ShowFileHints=0
ShowGridlines=0
ShowOnlyFiles=0
ShowParentFolder=1
IgnoreSizeOfLinkFolders=0
ShowColumnHeaders=1
UseLargeIconsForDetailsAndList=0
DblClickOnEmptySpaceAction=0
EnterOnSelectedFilesAction=1
OpenItemsWarningItemsCount=2
FilePanelColumnWidthListView=0
FileListItemShortingType=0
FormatTimestamp=
TimestampDateSeparator=
WorkerThreadsCount=4
DirMonSensibility=2
DirMonChangeInterval=500
DirMonIgnoreBkgChanges=0
DirMonAddNewToEnd=0
DirMonRefreshForAppActivating=0
DirMonIgnoreDrives=
FixedDriveIconType=0
RemoteDriveIconType=1
RemovableDriveIconType=1
CdromDriveIconType=1
IgnoreListForExtractedIcons=.cdr.
FileListItemColorsSetInThread=0
FunctionsBarVisible=0
FunctionsBarShowIcons=1
DosPrompt_Show=1
DosPrompt_CloseWin=0
DosPrompt_HistoryEnabled=1
DosCommandBoxSpec=
DosBoxAdminChangeFontColor=1
StatusBarWrapable=0
StatusBarShowSpacer=0
StatusBarAllowHiddenButtons=1
StatusBarHeight=20
AddrBarHotInUnderpart=0
AddrBarHotBtnSubfolders=0
AddrBarShowHistoryPopupOnClick=1
AddrBarHeight=24
AddrBarUseFcPopupForFolders=1
AddrBarFont_Name=Tahoma
AddrBarFont_Charset=1
AddrBarFont_Size=9
AddrBarFont_Bold=0
AddrBarFont_Italic=0
AddrBarFont_Underline=0
AddrBarFont_Strikeout=0
AddrBarFont_Color=536870911
AddrBarFont_ColorSelected=536870911
TabStyle=3
TabOnTop=1
TabSequence=0
TabMultiline=0
TabShowImages=0
TabUseLargeImages=0
TabImgPos=0
TabAddNewNearCurrent=0
TabAddNewColorFromCurrent=0
TabClickActiveChangeToLast=0
TabCloseBtnOnTab=1
TabCloseBtnScroller=1
TabCloseOnDblClick=1
TabShowMenuBtn=1
TabDragging=1
TabKeepOneOpen=1
TabShowDriveChar=1
TabShowDriveCharServer=1
TabBoldActiveTab=2
TabFileContainerFolder=%FcAppDataPath%\FileContainers
TabFileContainerRemoveTempOnPrgEnd=0
TabShowHints=0
TabCloseNotLockedOnClose=1
TabCloseUncOnClose=1
TabHistoryperTab=1
TabActivateWithLockedPath=1
TabAutoUnlockLockedPath=0
TabChar4Locked=#
TabCaptionLen=25
ThumbSpacingX=10
ThumbSpacingY=30
ThumbExtensionListForTextThumbs=
ThumbExtensionListIgnore=
ThumbTextFontSize=5
ThumbShowOnlyFiles=0
ThumbFoldersToo=1
ThumbAutoRotate=1
ThumbsShowOverlayIcons=1
ThumbsNoClipCaption=0
ThumbsShowCaptionQuickInfo=1
ThumbsPdfInternal=1
ThumbsLabelViewMaxLines=4
ThumbsLabelViewFontSize=9
ThumbsLabelCenterText=0
RenameUseDialog=0
RenameResolveIllegalChars=1
RenameUseClick=1
RenameOnClickPeriode=500
RenameSelectOnlyFileName=1
FileDeletePrg=0
FileDeleteCall=
FileCopyPrg=0
FileCopyCall=
FileMovePrg=0
FcCopyMoveVistaUp=0
FileMoveCall=
DragDropFileList=1
DragDropStartOnLabelOnly=1
DragDropTree=1
DragDropUseWindows=1
DragDropPopupLeftBtn=0
DragDropAlwaysCopyLeftBtn=0
DropSourceShowImage=1
DragDropMilisecForDragStart=200
DateFormatCreateFileFolder=yyyymmdd
TimestampFormatCreateFileFolder=yyyymmdd_hhnnss
DragDropRightMouseBtnOnly=0
NewFolderNameSuggestionList=
NewFileNameSuggestionList=
NewFileNameExtension=txt
PerformOpenPerItemExtList=.txt.
OperationQueueStatusVisibility=2
OperationQueueDlgOpenMinimized=1
OperationDlgQueueBtnDefault=0
OperationQueueUseStatusColor=0
OperationQueuePanelBelowStatus=0
OperationQueuePanelClosingTimeSec=8
CompareDirFileName=1
CompareDirFileSize=1
CompareDirFileDate=1
CompareDirFolderName=0
CompareDirFolderSize=0
CompareDirFolderDate=0
CompareDirIgnore2SecDiff=1
CompareDirSelectDifferent=1
CompareDirSelectOnlyNewer=1
CompareDirShowOnlySelected=1
CompareDirReloadBefore=1
CompareDirShowDialog=0
CompareIgnoreDiacriticalMarks=0
StartWithFixFolder=0
StartFolderLeft=
StartFolderRight=
TempFolder=
LogToFile=0
LogFolder=%FcTempPath%\FreeCommander.log
LogOperations=0
LogMsgType=0
LogFileCount=2
LogFileRotation=0
TreeColor=2105376
TreeInactiveColor=4210752
TreeColorSelectedNode=6842472
TreeColorSelectedNodeInactive=536870911
TreeHotNodeColorAdjustment=-24
TreeFontName=Tahoma
TreeFontCharset=1
TreeFontSize=9
TreeFontBold=0
TreeFontItalic=0
TreeFontUnderline=0
TreeFontStrikeout=0
TreeFontColor=13158600
TreeFontColorSelected=13158600
FavoritesTreeColor=2105376
FavoritesTreeInactiveColor=4210752
FavoritesTreeColorSelectedNode=6842472
FavoritesTreeColorSelectedNodeInactive=536870911
FavoritesTreeFontName=Tahoma
FavoritesTreeFontCharset=1
FavoritesTreeFontSize=9
FavoritesTreeFontBold=0
FavoritesTreeFontItalic=0
FavoritesTreeFontUnderline=0
FavoritesTreeFontStrikeout=0
FavoritesTreeFontColor=13158600
FavoritesTreeFontColorSelected=13158600
QuickFilterEditFieldColor=2105376
QuickFilterEditFieldFontColor=12632256
QuickFilterUseParentFont=1
QuickStarterBkgColor=8947848
QuickStarterTextColor=0
QuickStarterSelColor=-16777203
QuickStarterFont_Name=Tahoma
QuickStarterFont_Charset=1
QuickStarterFont_Size=9
QuickStarterFont_Bold=0
QuickStarterFont_Italic=0
QuickStarterFont_Underline=0
QuickStarterFont_Strikeout=0
QuickStarterFont_Color=536870911
QuickStarterFont_ColorSelected=536870911
GoUpColorStart=7895160
GoUpColorStop=11579568
VisualStyle=2
DialogsFontName=Tahoma
DialogsFontCharset=1
DialogsFontSize=9
DialogsFontBold=0
DialogsFontItalic=0
DialogsFontUnderline=0
DialogsFontStrikeout=0
DialogsFontColor=536870911
DialogsFontColorSelected=536870911
SplitterColorNoContentVisible=4737279
UseSplitterColorNoContentVisible=1
MultiRenameFontColorRed=7895295
MultiRenameFontColorGreen=8963149
MultiRenameFontColorGray=12566463
MultiRenameSelectedFontColorRed=128
MultiRenameSelectedFontColorGreen=12902822
MultiRenameSelectedFontColorGray=4934475
SearchDuplGroupBkgColor=4605510
SearchDuplSelRowFontColor=4356861
ShortcutsActiveShortcutColumnColor=3947580
Color-NcSelectedFont=2105376
Color-NcSelectedBkg=11579568
Color-NcSelectedBkg2=8421504
Color-NcSelectedBorder=3158064
Color-NcSelectedDrawBorder=0
Color-NcFocusedFont=13158600
Color-NcFocusedBkg=13158600
Color-NcFocusedBorder=-16777208
Color-NcFocusedBorderOnly=1
Color-NcFocusedBkgNoActiveList=-16777211
Color-NcFocusedBorderNoActiveList=7895160
Color-NcFocusedBorderOnlyNoActiveList=1
Color-NcHotFont=13158600
Color-NcHotBkg=-16777210
Color-NcHotUsingType=1
Color-HotBkgAdjustment=-24
WinSelectModeUseWinColors=0
Color-SelectedFont=2105376
Color-SelectedBkg=11579568
Color-SelectedBkg2=8421504
Color-SelectedBorder=3158064
Color-SelectedDrawBorder=0
Color-FocusedFont=13158600
Color-FocusedBkg=-16777211
Color-FocusedBorder=-16777208
Color-FocusedBorderOnly=1
Color-FocusedBkgNoActiveList=7895160
Color-FocusedBorderNoActiveList=7895160
Color-FocusedBorderOnlyNoActiveList=1
Color-HotFont=13158600
Color-HotBkg=-16777210
Color-HotUsingType=1
FileListColorBkg=2105376
FileListColorBkgInactiv=4210752
QuickFilterBackgroundColor=526408
FlatViewBackgroundColor=3158024
OnlySelectedBackgroundColor=4726824
FileListColorStripe=536870911
FileListFont_Name=Tahoma
FileListFont_Charset=1
FileListFont_Size=9
FileListFont_Bold=0
FileListFont_Italic=0
FileListFont_Underline=0
FileListFont_Strikeout=0
FileListFont_Color=13158600
FileListFont_ColorSelected=536870911
StatusBarColorStart=3158064
StatusBarColorStop=3684408
StatusBarFont_Name=Tahoma
StatusBarFont_Charset=1
StatusBarFont_Size=9
StatusBarFont_Bold=0
StatusBarFont_Italic=0
StatusBarFont_Underline=0
StatusBarFont_Strikeout=0
StatusBarFont_Color=10066329
StatusBarFont_ColorSelected=536870911
AddrBarActiveBkgColorStart=11579568
AddrBarActiveBkgColorStop=11579568
AddrBarActiveFontColor=3158064
AddrBarActiveBottomLineColor=536870911
AddrBarHotAreaColor=14342874
AddrBarInactiveBkgColorStart=8421504
AddrBarInactiveBkgColorStop=8421504
AddrBarInactiveFontColor=0
AddrBarInactiveBottomLineColor=536870911
AddrBarFilterFontColor=2171324
AddrBarHotAreaFontColor=536870911
TabColorActiveFont=2105376
TabColorActiveBkg1=11579568
TabColorActiveBkg2=11579568
TabColorHighlight=16777215
TabColorHotTrack=-16777190
TabColorHighlightOnlyActivePanel=0
TabColorActiveBtn=12632256
TabColorActiveBtnSymbol=7895160
TabColorActiveFont_FileContainer=14476
TabColorActiveBkg1_FileContainer=11579568
TabColorActiveBkg2_FileContainer=11579568
TabColorHighlight_FileContainer=16777215
TabColorInactiveFont=12632256
TabColorInactiveBkg1=5592405
TabColorInactiveBkg2=5592405
TabColorInactiveBtn=10000536
TabColorInactiveBtnSymbol=4210752
TabFont_Name=Tahoma
TabFont_Charset=1
TabFont_Size=9
TabFont_Bold=0
TabFont_Italic=0
TabFont_Underline=0
TabFont_Strikeout=0
TabFont_Color=536870911
TabFont_ColorSelected=536870911
TabColorInactiveFont_FileContainer=7577855
TabColorInactiveBkg1_FileContainer=5592405
TabColorInactiveBkg2_FileContainer=5592405
TabActiveUseOtherColorForInactivePanel=1
TabColorActiveBkg1InactivePanel=8421504
TabColorActiveBkg2InactivePanel=8421504
TabColorActiveBkg1InactivePanel_FileContainer=8421504
TabColorActiveBkg2InactivePanel_FileContainer=8421504
TabColorHighlightInactivePanel=11053224
TabColorHighlightInactivePanel_FileContainer=11053224
TabColorInactiveBkg1InactivePanel=5592405
TabColorInactiveBkg2InactivePanel=5592405
TabColorInactiveBkg1InactivePanel_FileContainer=5592405
TabColorInactiveBkg2InactivePanel_FileContainer=5592405
ThumbBkgColor=11579568
ThumbBkgColorTransparent=1
ThumbBorderColor=14211288
ThumbBorderSize=0
NetworkLoadOnPrgStartBkg=1
FileListColoredColumnHeader=1
FcDrawedFavoritesPopupMenu=0
SortColumnSymbol=1
TabCreateOnDblClickFreeSpace=1
FileListColorGridLine=536870911
FileListColorHeader=536870911
FileListColorHeaderHot=536870911
FileListColorHeaderFont=536870911
FileListColorHeaderBorder=536870911
FileListRowSelect=1
FileListMatchMaskWithAnsi=0
MiddleMouseClickOnFileIcon=0
MiddleMouseClickOnFileName=0
MiddleMouseClickOnFileExtension=0
MiddleMouseClickOnFileNameFreeSpace=0
MiddleMouseClickOnFolderIcon=0
MiddleMouseClickOnFolderName=0
MiddleMouseClickOnFolderNameFreeSpace=0
MiddleMouseClickOnFreeSpace=0
RightMouseClickOnFileIcon=0
RightMouseClickOnFileName=0
RightMouseClickOnFileExtension=0
RightMouseClickOnFileNameFreeSpace=0
RightMouseClickOnFolderIcon=0
RightMouseClickOnFolderName=0
RightMouseClickOnFolderNameFreeSpace=0
RightMouseClickOnFreeSpace=0
ShowFileHintsDuration=5000
ShowTruncatedCaptionHint=1
RenameReplaceCharForIllegal=_
FileListShowScrollbars=1
MiddleMouseClickOnFileDetailColumn=0
MiddleMouseClickOnFolderDetailColumn=0
RightMouseClickOnFileDetailColumn=0
RightMouseClickOnFolderDetailColumn=0
ThumbExtensionListWinCache=
ThumbsPdfFcInternal=0
QuickFilterHistoryReverseSorting=0
CopyPasteInThread=1
ShowWarningOnDeleteInFileContainer=1
DirMonPlainAllFolders=0
MiddleMouseClickOnFileOtherDetailColumns=0
MiddleMouseClickOnFolderOtherDetailColumns=0
RightMouseClickOnFileOtherDetailColumns=0
RightMouseClickOnFolderOtherDetailColumns=0
DriveBtnFontSize=9
ToggleSelection=0,2,1
FunctionsBarFontSize=9
ViewerUseWindowsOpenSaveDialogs=0
AlwaysLoadFileAllocatedMemorySize=0
TabLastUsedActivePaneOnly=1
TabLastUsedShowQuickFilter=0
TabLastUsedQuickFilterPath=1
TabCloseBtnOnAllTabs=0
TabSortOperationCaptionType=0
CompareDirFileMd5=0
ViewerFocusAfterOpenFile=0
SyncFoldersLeft2RightColor=536870911
SyncFoldersRight2LeftColor=536870911
SyncFoldersNoEqualColor=536870911
SearchDuplGroupFontColor=536870911
NewFolderDlgOpenLastPos=1
FileListShortenNameInMiddle=0
FileListShortenNameInMiddleEllipsis=...
TimeoutAccessNetwork=5000
TabShowSortedPopupMenu=1
FileListUseStripeInActivePaneOnly=0
DragDropUseExternal=0
WinExecutorCopyMoveIShellOperation=0
WinExecutorProgressDlgNoMinimize=0
ViewerMouseWheelPdf=0
ViewerMouseWheelPdfZoom=1
DetailedViewsAutoResizeWithTitles=0
FavoritesTreeAutoSort=0
ColorSchemaLightMode=
ColorSchemaDarkMode=
ColorSchemaAutoLightDarkMode=0
DialogsCreateOnMainFormMonitor=0
ProcessNr=0
CopyToClipboardHelper=1
TreeShowCloseBtn=1
[fcToolbarAction_Address]
1=actDirHistory;tbsButton;;;0;;0;0;0;0
2=actDirFavoriten;tbsButton;;;0;;0;0;0;0
3=actDirBack;tbsButton;;;0;;0;0;0;0
4=actDirRoot;tbsButton;;;0;;0;0;0;0
5=actEditCurDir2Clip;tbsDropDown;PopupMenuCopyPath2Clipboard;;0;;0;0;0;0
Visible=1
UseBigIcons=0
ScaleIconsOnHighDpi=0
BtnSize=24
TopBtnPos=55
BtnSmallFont=1
UseInLayouts=
CaptionAlign=0
[PopupMenuCopyPath2Clipboard]
1=actEditFilePath2Clip
2=actEditFileName2Clip
3=actEditFileNameWithoutExt2Clip
4=-
5=actEditCurDir2Clip83
6=actEditFilePath2Clip83
7=actEditFileName2Clip83
8=-
9=actEditCurDir2ClipWeb
10=actEditFilePath2ClipWeb
11=-
12=actEditCurDir2ClipUnc
13=actEditFilePath2ClipUnc
14=actEditFilePath2ClipUncWeb
15=-
16=actEditCopyDetailsToClip
[fcToolbarAction_FileCart]
1=actViewTabFileCartLoad;tbsButton;;;0;;0;0;0;0
2=actViewTabFileCartRemoveItem;tbsButton;;;0;;0;0;0;0
3=actViewTabFileCartSaveAs;tbsButton;;;0;;0;0;0;0
4=actEditCurDir2Clip;tbsDropDown;PopupMenuCopyPath2ClipboardFileCart;;0;;0;0;0;0
Visible=1
UseBigIcons=0
BtnSize=24
TopBtnPos=55
BtnSmallFont=1
UseInLayouts=
CaptionAlign=0
[PopupMenuCopyPath2ClipboardFileCart]
3=-
4=actEditCurDir2Clip83
5=actEditFilePath2Clip83
6=actEditFileName2Clip83
7=-
8=actEditCurDir2ClipWeb
9=actEditFilePath2ClipWeb
10=-
11=actEditCurDir2ClipUnc
12=actEditFilePath2ClipUnc
13=actEditFilePath2ClipUncWeb
[fcToolbarAction_Splitter]
1=actViewPanelsSwap;tbsButton;;;0;;0;0;0;0
2=actDirCompare;tbsButton;$FcPopup_Filters;;0;;0;-1;0;0
3=actExtrFavoriteTools;tbsButton;;;0;;0;0;0;0
4=actFileCopy;tbsButton;;;0;;0;0;1;0
5=actFileMove;tbsButton;;;0;;0;0;2;0
6=actFileView;tbsButton;;;0;;0;0;0;0
Visible=1
UseBigIcons=1
BtnSize=32
TopBtnPos=55
BtnSmallFont=1
UseInLayouts=
CaptionAlign=0
ShowRecycleBin=1
[fcToolbarAction_Standard]
1=actDirHistPrev;tbsDropDown;$FcPopup_HistoryFolders;;0;;0;0;0;0
2=actDirHistNext;tbsDropDown;$FcPopup_HistoryFolders;;0;;0;0;0;0
3=-;tbsDivider;$;;0;;0;0;8;-1
4=actFileView;tbsButton;;;0;;0;0;0;0
5=actFileEdit;tbsButton;;;0;;0;0;0;0
6=actFileCopy;tbsButton;;;0;;0;0;0;0
7=actFileMove;tbsButton;;;0;;0;0;0;0
8=actFileDelete;tbsButton;;;0;;0;0;0;0
9=actFileFindZip;tbsDropDown;$FcPopup_SearchProfiles;;0;;0;0;0;0
10=-;tbsDivider;;;0;;0;0;8;-1
11=actViewTree;tbsCheck;;;8;;0;0;0;0
12=actViewList;tbsCheck;;;1;;0;0;0;0
13=actViewDetails;tbsCheck;;;1;;0;0;0;0
14=actViewThumbDetails;tbsCheck;;;1;;0;0;0;0
15=actViewThumbDetails;tbsDropDown;$FcPopup_ThumbnailDetails;;-1;;-1;0;0;-1
16=actViewImgBrowser;tbsCheck;;;1;;0;0;0;0
17=actViewImgBrowser;tbsDropDown;$FcPopup_Thumbnails;;-1;;-1;0;0;-1
18=actViewRefreshAll;tbsButton;;;0;;0;0;0;0
19=-;tbsDivider;;;0;;0;0;8;-1
20=actDirControls;tbsButton;;;0;;0;0;0;0
21=actDirStartmenu;tbsDropDown;$FcPopup_StartMenu;;0;;0;0;0;0
22=actDirDesktopDir;tbsDropDown;$FcPopup_DesktopFolder;;0;;0;0;0;0
23=actDirSysFolder;tbsButton;;;0;;0;0;0;0
Visible=1
UseBigIcons=1
BtnSize=36
TopBtnPos=55
BtnSmallFont=1
UseInLayouts=
CaptionAlign=0
[ShellDetailsDlg_State]
Left=890
Top=400
Width=322
Height=381
State=0
FullScreen=0
[FcFormMain_State]
Left=347
Top=40
Width=1471
Height=966
State=0
FullScreen=0
ScreenPixelPerInch=96
VclStyle=1
[TfcViewerForm]
VlcPlayerVolume=0
VlcPlayerVolumeChangeStep=10
VlcPlayerSeekStepForMouseWheelMillisec=10000
VlcPlayerAudioMute=0
VlcPlayerBigIcons=1
VlcPlayerSnapshotFolder=
VlcPlayerOsdFontSize=22
TextFontName=Tahoma
TextCharset=1
TextFontSize=8
TextFontColor=-16777208
TextFontBold=0
TextFontItalic=0
TextFontUnderline=0
TextFontStrikeout=0
BinFontName=Tahoma
BinCharset=1
BinFontSize=8
BinFontColor=-16777208
BinFontBold=0
BinFontItalic=0
BinFontUnderline=0
BinFontStrikeout=0
HexFontName=Tahoma
HexCharset=1
HexFontSize=8
HexFontColor=-16777208
HexFontBold=0
HexFontItalic=0
HexFontUnderline=0
HexFontStrikeout=0
OemFontName=Terminal
OemCharset=1
OemFontSize=8
OemFontColor=-16777208
OemFontBold=0
OemFontItalic=0
OemFontUnderline=0
OemFontStrikeout=0
AutoDetectOemCodepage=0
IgnoreFilterList=~$*.doc*;
ExtList4TxtView=.txt.ini.log.def.bat.cmd.url.sql
ExtList4ImgView=.bmp.ico.wmf.emf.jpg.jpeg.jpe.jfif.png.gif.rle.dib.tga.tif.tiff.psd.fax.eps.icb.win.vst.vda.pcx.pcc.rpf.rla.sgi.rgba.rgb.bw.pdd.ppm.pgm.pbm.cel.pic.pcd.cut.pal.psp.jp2.jpc.pnm.ras.mis.ani.cur.
ExtList4MediaView=.avi.mpg.mpeg.mpe.mpv.mp3.mp2.mp1.m1v.m2v.mpv2.mp2v.mpa.m1a.m2a.asf.lsf.lsx.ivf.wav.mid.midi.rmi.kar.aif.aifc.aiff.au.snd.mov.qt.3gp.3gp2.3g2.3gpp.ra.rm.ram.rmvb.rpm.rt.rp.smi.smil.roq.asx.m3u.pls.wvx.wax.wmx.wmv.wma.wmp.wm.cda.ac3.dts.vob.ifo.d2v.fli.flc.flic.mka.mkv.ts.tp.tpr.pva.aac.mp4.ogm.ogg.divx.vp6.m4a.m4b.vqf.ape.mpc.flac.flv.dvr-ms.wtv.
ExtList4WinPreview=.pdf.msg.odt.doc.dot.docx.docm.xls.xlt.xlsx.xlsm.xlsb.ppt.pptx.pptm.pps.ppz.pot.wbk.wps.
ExtList4ImageEnPreview=.tif.tiff.fax.g3f.g3n.gif.jpeg.jpg.jpe.jif.jfif.pcx.bmp.dib.rle.ico.cur.png.dicom.dcm.dic.v2.wmf.emf.targa.tga.vda.icb.vst.pxm.pbm.pgm.ppm.wbmp.jp2.j2k.jpc.j2cpdfa.epdf.dcx.crw.cr2.cr3.dng.nef.raw.raf.x3f.orf.srf.mrw.dcr.bay.pef.sr2.arw.kdc.mef.3fr.k25.erf.cam.cs1.dc2.dcs.fff.mdc.mos.nrw.ptx.pxn.rdc.rw2.rwl.iiq.srw.psd.psb.iev.all.ien.imageen.lyr.hdp.wdp.jxr.dds.heic.heif.heics.avcs.heifs.avif.avifs.webp.svg
ExtList4RawImgView=.arw.crw.cr2.dng.mdc.mrw.nef.nrw.orf.raw.srf.sr2.
ExtList4WebView=.htm.html.xml.xsl.mht.pdf.swf.xps.shtml.xhtml.shtm.stm.php.php2.php3.asp.pl.vrml.plg.htt.htx.
ExtList4RtfView=.rtf
PdfUseInternalViewer=1
EpubUseInternalViewer=1
UseRawImageCache=0
CharsPerLine4BinView=80
CharsPerLine4TxtView=300
CharsPerLine4HexView=16
CharsPerLine4UnicodeView=300
TabSize=8
LinkToFileList=0
AutoDetectTextFiles=1
AutoFitText=0
AutoFitHex=0
ImageLabelVisible=1
ImageColorBkg=-16777211
UseIjlLib=0
ImageFit=1
ImageCenter=1
GifPlayAnimated=1
GifTransparency=1
WrapText=0
ColorBkgText=-16777211
ColorBkgHex=10789024
ColorHex1=0
ColorHex2=16711680
ColorImageLabel=255
ColorUrl=16711680
AutoReloadOnChanging=0
FollowTailAfterReload=0
BeepOnChanging=0
ShowGutter=0
ShowLineNrOnGutter=0
LinesBufSize=300
LinesMaxCount=2000
LinesStep=5
LinesExtUse=0
LinesExtList=.c.cpp.cs.h.hpp.pas.dpr.bas.asm.mak.inc.ini
LineNrFontName=Tahoma
LineNrCharset=1
LineNrFontSize=8
LineNrFontColor=-16777208
LineNrFontBold=0
LineNrFontItalic=0
LineNrFontUnderline=0
LineNrFontStrikeout=0
MediaPlayer=3
MediaAutoPlay=0
ShowLastSearchMatchDlg=0
ShowTitleBar=1
TitelBarColorBkg=12632256
TitelBarFontName=Verdana
TitelBarCharset=1
TitelBarFontSize=9
TitelBarFontColor=32896
TitelBarFontBold=0
TitelBarFontItalic=0
TitelBarFontUnderline=0
TitelBarFontStrikeout=0
ToolbarLocked=0
MaxFileSizeRtf=8
ExtPrgPath=
ExtPrgExtList=.aif.ani.cur.awd.b3d.bmp.dib.clp.dds.acr.djvu.ecw.emf.wmf.eps.ps.fits.fpx.fsh.g3.gif.hdr.icl.iff.lbm.img.gem.jpg.jp2.jpm.kdc.ldf.lwf.med.mng.jng.ov.mrsid.nlm.nol.ngg.pbm.pgm.ppm.pcx.dcx.photocd.png.psd.psp.pvr.ras.sun.raw.rle.sff.sfw.sgi.rgb.tga.tif.tiff.ttf.wad.wbmp.xbm.xpm.crw.cr2.vtf.dng.nef.orf.raf.mrw.dcr.x3f.pef.srf.eff.dxf.dwg.hpgl.cgm.svg.
ExtPrgEnabled=0
ExifTool=
ExifToolFileExtensions=
ExifToolLanguage=
ExifToolCustomerCmdLineOpt=
ExifToolTagsViewType=0
MetadataUseExiftool=0
PluginsHighPriority=1
FindWords=0
FindCase=0
FindHex=0
FindRegEx=0
FindAll=1
FindOrigin=0
ImageColorBkgToggle1=3355443
ImageColorBkgToggle2=8799492
ImageColorBkgToggle3=12632256
MagnifierShowBorders=1
MagnifierStyle=0
MagnifierRate=4
MagnifierSize=200
ActivateCropOnImageLoading=0
[fcActionToolbars]
ToolbarsLock=0
[Icons]
IconsSet=1
Main_SmallSize0=20
Main_LargeSize0=32
Main_MenuSize0=20
Main_OKCancelIconsType0=1
Main_SmallSize1=16
Main_LargeSize1=32
Main_MenuSize1=16
Main_OKCancelIconsType1=1
Dlg_SmallSize0=20
Dlg_LargeSize0=32
Dlg_MenuSize0=20
Dlg_OKCancelIconsType0=1
Dlg_SmallSize1=16
Dlg_LargeSize1=32
Dlg_MenuSize1=16
Dlg_OKCancelIconsType1=1
SymbolSpacing=1
[MainPanel]
ShowDrives=0
ShowTree=0
ShowFavoriteTree=0
ShowViewer=0
ShowGoUp=0
LastPanelOrientation=0
MainSplitterPos=48
MainSplitterOrient=0
LeftShowTree=0
LeftShowFavoriteTree=0
LeftTreeAlign=0
LeftShowViewer=0
LeftViewerAlign=0
LeftShowDrives=1
LeftDir=C:\Users\jdunn\AppData\Local\FreeCommanderXE
LeftViewStyle=3
LeftShowFolderSize=0
LeftSortColumn=0,0,-1,0
LeftThumbSize=96
LeftDetailsProfile=fc_default_view
RightShowTree=0
RightShowFavoriteTree=0
RightTreeAlign=0
RightShowViewer=0
RightViewerAlign=0
RightShowDrives=1
RightDir=C:\Users\jdunn\AppData\Local\FreeCommanderXE
RightViewStyle=3
RightShowFolderSize=0
RightSortColumn=0,0,-1,0
RightThumbSize=96
RightDetailsProfile=fc_default_view
[fcDlgCopyMove_State]
Left=825
Top=420
Width=465
Height=340
State=0
FullScreen=0
VclStyle=1
[DlgSettings_State]
Left=311
Top=188
Width=1186
Height=743
State=0
FullScreen=0
VclStyle=1
[DlgSettings]
LastGroup=3
LastTabSheet=tabSheetPrgEditors
[dlgShortcutsDefine_State]
Left=272
Top=226
Width=1393
Height=789
State=0
FullScreen=0
VclStyle=0
[TdlgShortcutsDefine]
Col1=288
Col2=173
Col3=161
Col4=173
ColorColumnActiveShortcut=-16777192
[dlgInputBox_State]
Left=897
Top=444
Width=368
Height=159
State=0
FullScreen=0
VclStyle=1
[fcRenameFileDlg_State]
Left=208
Top=208
Width=401
Height=283
State=0
FullScreen=0
[RenameDlg]
UseOneField=0
[dlgFcAttrTimestamp_State]
Left=234
Top=234
Width=1393
Height=789
State=0
FullScreen=0
[dlgFcAttrTimestamp]
AutoCloseOnSuccess=1
AutoCloseOnCancel=0
CurrentTimestampOnOpen=0
DlgIcon=
[dlgFcFilterSet_State]
Left=883
Top=236
Width=380
Height=616
State=0
FullScreen=0
[TfcViewerFormToolbars_ViewerStandard]
1=actFilePrevious;tbsButton;;;0;;0;0;0;0
2=actFileNext;tbsButton;;;0;;0;0;0;0
3=-;tbsDivider;;;0;;0;0;8;-1
4=actFileLinkToFileList;tbsCheck;;;19;;0;0;0;0
5=actFileReload;tbsButton;;;0;;0;0;0;0
6=actFileEdit;tbsButton;;;0;;0;0;0;0
7=actFileDelete;tbsButton;;;0;;0;0;0;0
8=actFileProperties;tbsButton;;;0;;0;0;0;0
9=actEditFind;tbsCheck;;;2;;0;0;0;0
11=actViewTextFont;tbsButton;;;0;;0;0;0;0
12=actViewTextWrap;tbsCheck;;;5;;0;0;0;0
13=actViewTextNumbering;tbsCheck;;;3;;0;0;0;0
14=-;tbsDivider;;;0;;0;0;8;-1
15=actViewPlus;tbsButton;;;0;;0;0;0;0
16=actViewMinus;tbsButton;;;0;;0;0;0;0
17=actViewOrigSize;tbsButton;;;0;;0;0;0;0
18=actViewWinSize;tbsButton;;;0;;0;0;0;0
19=actViewRotateClockwise90;tbsButton;;;0;;0;0;0;0
20=actViewRotateAntiClockwise90;tbsButton;;;0;;0;0;0;0
21=-;tbsDivider;;;0;;0;0;8;-1
22=actViewModeText;tbsCheck;;;1;;0;0;0;0
23=actViewModeBinText;tbsCheck;;;1;;0;0;0;0
24=actViewModeTextHex;tbsCheck;;;1;;0;0;0;0
25=actViewModeTextUnicode;tbsCheck;;;1;;0;0;0;0
26=actViewModeTextRtfUtf;tbsCheck;;;1;;0;0;0;0
27=actViewModeImages;tbsCheck;;;1;;0;0;0;0
28=actViewModeImageMultimedia;tbsCheck;;;1;;0;0;0;0
29=actViewModeInternetOffice;tbsCheck;;;1;;0;0;0;0
30=actViewModeWinPreview;tbsCheck;;;1;;0;0;0;0
31=actViewModePlugin;tbsButton;;;1;;0;0;0;0
32=-;tbsDivider;;;0;;0;0;8;-1
33=actOptionsConfigure;tbsButton;;;0;;0;0;0;0
Visible=1
UseBigIcons=0
BtnSize=24
TopBtnPos=55
BtnSmallFont=1
UseInLayouts=
CaptionAlign=0
[fcViewerForm_State]
Left=163
Top=156
Width=561
Height=590
State=0
FullScreen=0
VclStyle=1
[dlgFcCopyMoveOperation_Copy]
UseLastOverwriteOptions=0
AutoCloseOnCancel=0
AutoMinimizeOnStart=0
UseUnbufferedOperation=0
UnbufferedOperationSizeLimit=4
UseCurrentDir=0
UnpackInSubfolder=0
PreserveCreationDate=0
UseRecycleBinForOverwriting=0
AutoScrollFileList=0
[fcFormMultiRename_State]
Left=163
Top=156
Width=791
Height=508
State=0
FullScreen=0
VclStyle=1
[dlgOverwriteConfirm_State]
Left=207
Top=249
Width=400
Height=462
State=0
FullScreen=0
VclStyle=1
[fcCustomGradientStyle]
ColorStart=3289650
ColorStop=2763306
Gradient=5
SelectionColorStart=14651440
SelectionColorStop=14651440
FontColor=15132390
BorderColor=3158064
MenuColorStart=3289650
MenuColorStop=2763306
MenuGradient=3
MenuSelectionColorStart=14651440
MenuSelectionColorStop=14651440
MenuIconBarColorStart=3289650
MenuIconBarColorStop=3289650
MenuColorInactiveItem=6316128
MenuColorLine=6316128
MenuFontColor=15132390
MenuBorderColor=6316128
[QuickStarterItemColorsByFileType]
1=*.txt;*.lng|536870911
2=*.ini|536870911
[selectFolderDialog_State]
Left=737
Top=363
Width=383
Height=354
State=0
[fcDlgNewFolder_State]
Left=85
Top=78
Width=517
Height=190
State=0
FullScreen=0
VclStyle=1
[TfcDlgNewFolder]
NamePattern=
CounterStart=1
CounterStep=1
CounterDigits=3
TimestampStep=1
TimestampStepUnit=2
TimestampFormat=yyyy-mm-dd hh-nn-ss
[dlgFcDeleteOperation_State]
Left=189
Top=182
Width=441
Height=461
State=0
FullScreen=0
VclStyle=1
[dlgFcDeleteOperation]
UsePlainView=1
UseVistaMethod=0
AutoCloseOnCancel=0
ShowErrorUI=1
WipeOverwriteRuns=1
[dlgFcCopyMoveOperation_State]
Left=241
Top=234
Width=476
Height=489
State=0
FullScreen=0
VclStyle=1
[fcSearchForm_State]
Left=111
Top=104
Width=755
Height=520
State=0
FullScreen=0
VclStyle=1
[TfcFrameQuickOperations]
colWidth0=40
colWidth1=160
colWidth2=250
colWidth3=90
colWidth4=75
colWidth5=110
colWidth6=110
colWidth7=0
colWidth8=0
colWidth9=0
[PrgDefaultAction]
Enabled1=0
Filter1=*.mp4
Prg1=D:\UT\mpv\mpv.exe
TargetExt1=.txt
Param1=--no-input-default-bindings %ActivDir%\%ActivItem%
[PrgEditors]
Enabled1=0
Prg1=%windir%\system32\mspaint.exe
TargetExt1=.txt
Enabled2=0
Prg2=%windir%\system32\mspaint.exe
TargetExt2=.txt
Enabled3=1
Filter3=*
Prg3=C:\Program Files\Notepad++\notepad++.exe
TargetExt3=.txt
Param3=%ActivSel%
[PrgExtViewers]
Enabled1=1
Filter1=*
TargetExt1=.txt
Param1=--no-input-default-bindings %ActivSel%
Enabled2=0
Filter2=*
Prg2=C:\Program Files\Notepad++\notepad++.exe
TargetExt2=.txt
Param2=%ActivSel%
[PrgFileCompare]
Enabled1=0
Filter1=*
Prg1=C:\Program Files (x86)\PSPad editor\PSPad.exe
TargetExt1=.txt
Param1=-D %FileCompare1% %FileCompare2%
[ViewerExifToolTags1]
FileExtensions=*
[fcToolbarAction_Left border]
Visible=0
UseBigIcons=0
BtnSize=24
TopBtnPos=55
BtnSmallFont=1
UseInLayouts=
CaptionAlign=0
[fcToolbarAction_Right border]
Visible=0
UseBigIcons=0
BtnSize=24
TopBtnPos=55
BtnSmallFont=1
UseInLayouts=
CaptionAlign=0
[FcStatusInfo]
1=FcDefault__0Parent
2=FcDefault__jpg
3=FcDefault__0
4=FcDefault__2
5=FcDefault__3
6=FcDefault__1
[FcStatusInfo_FcDefault__0Parent]
SelectionType=0
FileFilter=..
0Text=#5B#fc_countAll#5D##20#Object(s)
0Hint=Folders:#20##5B#fc_countFolders#5D##NL#Files:#20##5B#fc_countFiles#5D#
0FontColor=536870911
1Text=#5B#fc_sizeAutoSel#5D#
1Hint=#5B#fc_sizeSel#5D##20#Byte(s)#NL##5B#fc_sizeKBSel#5D##NL##5B#fc_sizeMBSel#5D#
1FontColor=536870911
2Text=(Free#20##5B#fc_discFree#5D#)
2Hint=
2FontColor=536870911
[FcStatusInfo_FcDefault__jpg]
SelectionType=0
0Text=#5B#fc_sizeAutoSel#5D#
0Hint=#5B#fc_sizeSel#5D##20#Byte(s)#NL##5B#fc_sizeKBSel#5D##NL##5B#fc_sizeMBSel#5D#
1Text=#5B#exif_taken#5D#
1Hint=
2Text=#5B#exif_width#5D#x#5B#exif_hight#5D#
2Hint=
3Text=ISO-#5B#exif_iso#5D#
3Hint=
3FontColor=536870911
4Text=#5B#exif_fnumber#5D#
4Hint=
4FontColor=536870911
5Text=#5B#exif_cmodel#5D#
5Hint=#5B#exif_camera#5D#
5FontColor=536870911
6Text=(Free#20##5B#fc_discFree#5D#)
6Hint=
6FontColor=536870911
[FcStatusInfo_FcDefault__0]
SelectionType=0
FileFilter=
0Text=#5B#fc_countSel#5D#/#5B#fc_countAll#5D##20#Object(s)#20#selected
0Hint=
2Text=#5B#fc_dtMod#5D#
2Hint=Created:#20##5B#fc_dtCre#5D##NL#Last#20#access:#20##5B#fc_dtAcc#5D#
3Text=#5B#fc_attrStr#5D#
3Hint=
4Text=(Free#20##5B#fc_discFree#5D#)
4Hint=
[FcStatusInfo_FcDefault__2]
SelectionType=2
FileFilter=
0Text=#5B#fc_pathRelative#5D#
0Hint=#5B#fc_path#5D#
1Text=#5B#fc_countSel#5D#/#5B#fc_countAll#5D##20#Object(s)#20#selected
1Hint=
2Text=#5B#fc_sizeAutoSel#5D#
2Hint=#5B#fc_sizeSel#5D##20#Byte(s)#NL##5B#fc_sizeKBSel#5D##NL##5B#fc_sizeMBSel#5D#
3Text=(Free#20##5B#fc_discFree#5D#)
3Hint=
[FcStatusInfo_FcDefault__3]
SelectionType=3
FileFilter=
1Hint=
3Hint=
[FcStatusInfo_FcDefault__1]
SelectionType=1
FileFilter=
0Hint=
2Hint=
[FcDetailedViews]
1=fc_default_view
[FcDetailedViews_fc_default_view]
LoadShellTitle=1
Condition=
ShowExtensionInCaption=1
ItemsCountRecursive=0
SizeCountRecursive=1
LastSorting=0,0,-1,0
AutoSizeNameColumn=0
1col_Name=Name
1col_Format=
1col_Align=0
1col_Width=54
1col_Sort=0
1col_ContentType=0
1col_ShellContentType=0
1col_RefValue=
1col_Content=0
1col_LvIndex=0
2col_Name=Size Auto
2col_Format=
2col_Align=1
2col_Width=16
2col_Sort=1
2col_ContentType=0
2col_ShellContentType=1
2col_RefValue=
2col_Content=6
2col_LvIndex=1
3col_Name=Modified
3col_Format=
3col_Align=0
3col_Width=24
3col_Sort=1
3col_ContentType=0
3col_ShellContentType=2
3col_RefValue=
3col_Content=9
3col_LvIndex=2
[ItemColorsByAttributes]
AttrColor1=22|4747376|0|2|0
AttrColor2=20|4747376|0|2|0
AttrColor3=18|4747376|0|2|0
AttrColor4=17|8429728|0|2|0
AttrColor5=16|11589848|0|2|0
AttrColor6=6|7368816|0|2|-1
AttrColor7=4|7368816|0|2|-1
AttrColor8=2|7368816|0|2|-1
AttrColor9=1|9474192|0|2|-1
[ItemColorsByFileType]
1=*.7z;*.ace;*.cab;*.lha;*.lzh;*.pak;*.rar;*.tar;*.tgz;*.zip;*.iso;*.img;*.nrg;*.bin;*.cue;*.mdf;*.mds;*.isz|74494128
2=*.exe;*.bat;*.com;*.cmd;*.scr|9211135
[PackerPlugins]
Title1=fcZip
Ext1=zip.jar.war.ear
File1=-1,607,"fc_internal_zip",-1
SfxFile1=
Title2=fcRar
Ext2=rar
File2=-1,68,"fc_internal_rar",-1
SfxFile2=
Title3=fc7Zip
Ext3=7z
File3=-1,607,"fc_internal_7z",-1
SfxFile3=%FcSrcPath%\fc7z.sfx
[TfcTabControl_Left]
1=743BDF0B-25E6-4BA0-90D7-E7A5DF7231F0
ActiveTab=743BDF0B-25E6-4BA0-90D7-E7A5DF7231F0
[Tab_743BDF0B-25E6-4BA0-90D7-E7A5DF7231F0]
Caption=
Path=C:\Users\jdunn\AppData\Local\FreeCommanderXE
PathLastUsed=C:\Users\jdunn\AppData\Local\FreeCommanderXE
PathDefined=
DriveRelative=0
LockType=0
ColorFont=536870911
ColorStart=536870911
ColorStop=536870911
AlwaysUseCustomColors=0
TreeVisible=0
TreeRootToLockedPath=0
TreeVisibility=0
ViewStyle=3
ThumbSize=96
IconLarge=0
IconFile=
IconIdx=0
Sort=0,0,-1,0
Filter=
QuickFilter=
FlatView=0
DetailedView=fc_default_view
[TfcTabControl_Right]
1=F86BC481-A618-4C20-9001-C0D9F6BAD9C9
ActiveTab=F86BC481-A618-4C20-9001-C0D9F6BAD9C9
[Tab_F86BC481-A618-4C20-9001-C0D9F6BAD9C9]
Caption=
PathDefined=
DriveRelative=0
LockType=0
ColorFont=536870911
ColorStop=536870911
TreeVisible=0
TreeVisibility=0
ViewStyle=3
ThumbSize=96
IconLarge=0
IconFile=
IconIdx=0
Sort=0,0,-1,0
Filter=
QuickFilter=
FlatView=0
DetailedView=fc_default_viewRe: 946 (Portable) - I no longer have "press enter to run"
It is only freecommander.ini file.
No problem if I use the settings with 946.
The shortcuts file (freecommander.shc) would be important.
Try it: close FC, rename freecommander.shc, start FC, check ENTER.
Here is my "freecommander.shc" file
[ShortCuts]
actFileViewEx=Ctrl+Enter
actDosPromptItem2Command=0
actHelpIndex=F1
[ShortCuts]
actHelpIndex=F1
Users browsing this forum: Bing [Bot] and 56 guests
