Search sub-window could use a better header for its items
#1 Post by Forez » 22.03.2026, 11:48
After pressing of CTRL+F, the somewhat new option of
Search files/folders > Options > Search result - columns...
that allows for arranging of Columns shows a short list of them
I propose renaming the current
<< Name >>
header to
<< Column name >>
or
>> Name of Columns <<
because currently at first glance it looks like some kind of glitchy repetition when user sees
<< Name >>
Name
near the top of that Search result - columns... window
I am using Build 946 64-bit Donor Portable and Build 941 32-bit Public Installed
