Edit a Saved Profile
Posted: 06.05.2026, 20:24
by sdaughtry
I cannot locate an option to edit a saved profile within the Multi Rename window; if it exists please tell me how to edit/re-save a renaming profile - if it doesn't exist I'm requesting this feature to be added. I frequently need to "fine-tune" renaming profiles.
Re: Edit a Saved Profile
Posted: 07.05.2026, 08:13
- Open multi rename dialog
- Select Profiles tab
- Select profile you want change
- Click on button "Apply selected profile"
- On the Settings tab make changes you want
- Go to Profiles tab
- Use + button for saving new profile
- Remove old profile
- Close the dialog
