Show File Size
Posted: 28.01.2010, 07:22
In my configuration of FreeCommander I would like to to have both panels show the same columns in detail view. For an individual file I would like to see the file's name, the file's size, date of last modification, and creation date. Out of all of these, there are 2 items that I would like to have always displayed are the file's name and the file's size.
The way that my program is presently configured the settings are configured the way that I want while the other panel does not display the file's size. The option to use the detailed view has been selected for both panels.
I have installed the FreeCommander twice this evening in attempts to get the program's configuration the way that I would like it. I would like each panel to show columns in the "detailed" format. I also would like to have the placement of each the columns in both panels be the same in size and in heading. I thought that setting the program up program to suit my taste would be easy. Whenever I have trouble, I push the "F1" or start searching for answers in the program's help file.
I have tried to get FreeCommander's help file to work by putting it in the same folder as the program's installation files, I put a copy in the program's directory and I have even shoved one up its .... That is aggravation number one. No matter how I have tried to get that help file installed I have been foiled at every turn. What really makes so aggravating to me is that one or two out of the dozens of times that I have installed, uninstalled, and reinstalled "FreeCommander" the help file was actually installed correctly.
Major aggravation number two: since I was not able to find a heading in the help file that alluded to how to set up a column to display a file's size (it was not any problem to set up a folder size). I decided to search for the phrase "show file size". The answer that was returned was of no help. In the answer that I received each of the 3 words that I had searched on were listed individually and a notice was displayed that said because each of the words were common and that the words that I used in my search phrase were "small words" - I think that means that the words contain very few letters, I was told that I could not use any of the 3 words in my search phrase. Now what can I do? I want to look for specific words but when I tried to search for I get an error message saying that each of the words are illegal and that no search can be conducted using one or combination of any of the 3 that I had just used. I think that means I cannot search for any of the terms that I want to search for.
I am sure that there is a easy solution to my problem but I have become too frustrated to look for the solution any further. Being "shot down" by the search engine was the final straw.
Will someone please help me? I would like to be able to show the size of the files that are listed in "FreeCommander".
I would like to have both panels show the same columns in detail view. For a file I would like to see the file's name, the file's size, date of last modification, and creation date. Out of all of these, there are 2 items that I would like to have always displayed, and I was most important for me to see include the file's name and the file's size.
The way that my program is presently configured, the settings for one of the panels are configured the way that I want - while the other panel does not display the file's size. The option to use the detailed view has been selected for both panels.
I have tried to get a help file to work with by putting it in the same folder as the program's installation files, I put a copy in the program's directly, and I have even even shoved one up its .... That is aggravation number one. No matter how I have tried to get that help file installed I have been foiled at every turn. What really makes an aggravation is that one or two out of the dozens of times that I have installed, uninstalled, and reinstalled "FreeCommander" the help file was actually installed correctly.
Major aggravation number two: since I was not able to find a heading in the help file that alluded to how to set up a column to display a file's size (it was not any problem to set up a folder size). I decided to search for the phrase "show file size". The answer that was returned was of no help. In the answer each of the 3 words that I had searched upon was listed individually and a notice was displayed that said because each of the words were common and that the words that I used in my search phrase were "small words" - I think that means that the words contain very few letters, I told that I could not use any of the 3 words in my search phrase. Now what can I do? I want to look for specific words but when I tried to search for I get an error message saying that each of the words are illegal and that no search can be conducted using one or combination of any of the 3 that I had just used. I think that means I cannot search for the things that I want to search for.
