FC start up delay
jack purvis
FC start up delay
#1 Post by jack purvis » 07.02.2010, 01:51
I love FC but it takes on average 16 seconds to load the program from the time I click the icon. Is this standard? Or is there a fix? Just asking :)
clanman
Re: FC start up delay
#2 Post by clanman » 07.02.2010, 22:27
If you have folder view turned on and you are accessing a network drive, this may be your problem. FC has known issues with network drives.
The other thing you can do is rename your freecommander.ini file then start the app. This will ensure you get a clean start.
Regards
Clanman
Using FreeCommander XE 2022 Build 860 32-bit public on Windows 11
Users browsing this forum: No registered users and 160 guests
